Trying to connect to a ble device, once I connect and discover the notification characteristic I activate it, but in the callback function it always returns null, I don't understand where I'm going wrong, the notification should send me different signals all the time.
here is my code ,
thanks for the help
/* main.c - Application main entry point */
* Copyright (c) 2020 SixOctets Systems
#include <stdio.h>
#include <stddef.h>
#include <errno.h>
#include <zephyr/kernel.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#define NAME_LEN 100
static int scan_start(void);
static struct bt_conn *default_conn;
static struct bt_uuid_16 uuid = BT_UUID_INIT_16(0);
static struct bt_gatt_discover_params discover_params;
static struct bt_gatt_subscribe_params subscribe_params;
static uint8_t notify_func(struct bt_conn *conn,
struct bt_gatt_subscribe_params *params,
const void *data, uint16_t length)
// if (!data) {
// printk("[UNSUBSCRIBED]\n");
// params->value_handle = 0U;
// return BT_GATT_ITER_STOP;
printk("[NOTIFICATION] data %p length %u\n", data, length);
return BT_GATT_ITER_CONTINUE;
static uint8_t discover_func(struct bt_conn *conn,
const struct bt_gatt_attr *attr,
struct bt_gatt_discover_params *params)
struct bt_gatt_service_val *gatt_service;
struct bt_gatt_chrc *gatt_chrc;
struct bt_gatt_include *gatt_include;
char str[37];
if (!attr) {
printk("Discover complete\n");
memset(params, 0, sizeof(*params));
switch (params->type) {
case BT_GATT_DISCOVER_SECONDARY:
case BT_GATT_DISCOVER_PRIMARY:
gatt_service = attr->user_data;
bt_uuid_to_str(gatt_service->uuid, str, sizeof(str));
printk("Service %s found: start handle %x, end_handle %x\n",
str, attr->handle, gatt_service->end_handle);
case BT_GATT_DISCOVER_CHARACTERISTIC:
gatt_chrc = attr->user_data;
bt_uuid_to_str(gatt_chrc->uuid, str, sizeof(str));
if (strcmp(str, "6e400002-b5a3-f393-e0a9-e50e24dcca9e")==0)
printk("Characteristic %s found: handle %x\n", str,
attr->handle);
printk("Found characteristic to write\n");
// Valore da scrivere
uint8_t value[] = {0x01, 0x00};
// Scrittura senza risposta
int err = bt_gatt_write_without_response(conn, attr->handle, &value, sizeof(value), false);
if (err) {
printk("Failed to write value, err: %d\n", err);
} else {
printk("Value written successfully\n");
}else if (strcmp(str, "6e400003-b5a3-f393-e0a9-e50e24dcca9e")==0)
attr->handle);
subscribe_params.notify = notify_func;
subscribe_params.value = BT_GATT_CHRC_NOTIFY;
subscribe_params.ccc_handle = attr->handle;
int err = bt_gatt_subscribe(conn, &subscribe_params);
if (err && err != -EALREADY) {
printk("Subscribe failed (err %d)\n", err);
} else {
printk("[SUBSCRIBED]\n");
case BT_GATT_DISCOVER_INCLUDE:
gatt_include = attr->user_data;
bt_uuid_to_str(gatt_include->uuid, str, sizeof(str));
printk("Include %s found: handle %x, start %x, end %x\n",
str, attr->handle, gatt_include->start_handle,
gatt_include->end_handle);
bt_uuid_to_str(attr->uuid, str, sizeof(str));
printk("Descriptor %s found: handle %x\n", str, attr->handle);
static bool data_cb(struct bt_data *data, void *user_data)
char *name = user_data;
uint8_t len;
switch (data->type)
case BT_DATA_NAME_SHORTENED:
case BT_DATA_NAME_COMPLETE:
len = MIN(data->data_len, NAME_LEN - 1);
(void)memcpy(name, data->data, len);
name[len] = '\0';
return false;
return true;
static bool eir_found(struct bt_data *data, void *user_data)
bt_addr_le_t *addr = user_data;
int i;
printk("[AD]: %u data_len %u\n", data->type, data->data_len);
switch (data->type)
case BT_DATA_UUID16_SOME:
case BT_DATA_UUID16_ALL:
if (data->data_len % sizeof(uint16_t) != 0U)
printk("AD malformed\n");
return true;
for (i = 0; i < data->data_len; i += sizeof(uint16_t))
struct bt_uuid *uuid;
uint16_t u16;
int err;
memcpy(&u16, &data->data[i], sizeof(u16));
uuid = BT_UUID_DECLARE_16(sys_le16_to_cpu(u16));
if (bt_uuid_cmp(uuid, BT_UUID_HTS))
continue;
err = bt_le_scan_stop();
if (err)
printk("Stop LE scan failed (err %d)\n", err);
continue;
err = bt_conn_le_create(addr, BT_CONN_LE_CREATE_CONN,
BT_LE_CONN_PARAM_DEFAULT,
&default_conn);
if (err)
printk("Create connection failed (err %d)\n",
err);
scan_start();
return false;
return true;
static void device_found(const bt_addr_le_t *addr, int8_t rssi, uint8_t type,
struct net_buf_simple *ad)
char name[NAME_LEN];
uint16_t data_len;
(void)memset(name, 0, sizeof(name));
data_len = ad->len;
bt_data_parse(ad, data_cb, name);
if (strcmp(name, "") != 0)
if (strstr(name, "OxySmart") != NULL){
printk("[nome]: %s \n", name);
char dev[BT_ADDR_LE_STR_LEN];
bt_addr_le_to_str(addr, dev, sizeof(dev));
printk("[DEVICE]: %s, AD evt type %u, AD data len %u, RSSI %i\n",
dev, type, ad->len, rssi);
int err = bt_le_scan_stop();
if (err)
&default_conn);
if (err)
err);
scan_start();
/* We're only interested in connectable events */
// bt_data_parse(ad, eir_found, (void *)addr);
/* Use active scanning and disable duplicate filtering to handle any
* devices that might update their advertising data at runtime.
struct bt_le_scan_param scan_param = {
.type = BT_LE_SCAN_TYPE_ACTIVE,
.options = BT_LE_SCAN_OPT_NONE,
.interval = BT_GAP_SCAN_FAST_INTERVAL,
.window = BT_GAP_SCAN_FAST_WINDOW,
return bt_le_scan_start(&scan_param, device_found);
static void connected(struct bt_conn *conn, uint8_t conn_err)
int err;
if (conn_err)
printk("Failed to connect to %s (%u)\n", addr, conn_err);
bt_conn_unref(default_conn);
default_conn = NULL;
scan_start();
return;
printk("Connected: %s\n", addr);
if (conn == default_conn)
memcpy(&uuid, BT_UUID_HTS, sizeof(uuid));
discover_params.uuid = NULL;
discover_params.func = discover_func;
discover_params.start_handle = BT_ATT_FIRST_ATTRIBUTE_HANDLE;
discover_params.end_handle = BT_ATT_LAST_ATTRIBUTE_HANDLE;
discover_params.type = BT_GATT_DISCOVER_CHARACTERISTIC;
err = bt_gatt_discover(default_conn, &discover_params);
if (err)
printk("Discover failed(err %d)\n", err);
return;
int err;
printk("Disconnected: %s (reason 0x%02x)\n", addr, reason);
if (default_conn != conn)
return;
err = scan_start();
if (err)
printk("Scanning failed to start (err %d)\n", err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
.connected = connected,
.disconnected = disconnected,
int err;
err = bt_enable(NULL);
if (err)
printk("Bluetooth init failed (err %d)\n", err);
return 0;
printk("Bluetooth initialized\n");
err = scan_start();
if (err)
return 0;
printk("Scanning successfully started\n");
return 0;
