usb_cdc_acm: cdc_acm_poll_out: Ring buffer full, drain buffer
Windows 11, NCS v2.3.0, VSCode
Hi, I have an application sending a regular stream of data to a PC via USB UART, and I got this error:
The device was operating normally, at a steady unchanging rate for a few hours, and all of a sudden this error presented itself hundreds/thousands of times before I shut off the link to the PC, at which point the error stopped.
In another ticket I raised 2 days ago (link) I outline that my code is attempting to not send data when no dtr, it just discards it.  Not clear to me how I could have filled up any buffer that way, or even filled a buffer at the very slow rate of sending I was doing in the first place.
I have included the build/zephyr/.config file here (renamed to allow attaching)
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
# CONFIG_SPI is not set
CONFIG_GPIO_INIT_PRIORITY=40
CONFIG_WATCHDOG=y
# CONFIG_MODEM is not set
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_BOARD="nrf52840core"
CONFIG_SOC="nRF52840_QIAA"
CONFIG_SOC_SERIES="nrf52"
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
# CONFIG_RESET is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
# CONFIG_FPU is not set
# CONFIG_MBEDTLS is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=4096
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UART_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.3.0/nrf)
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_INIT_STACKS=y
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
CONFIG_LOG_DEFAULT_LEVEL=4
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_ESB_LOG_LEVEL_OFF is not set
# CONFIG_ESB_LOG_LEVEL_ERR is not set
# CONFIG_ESB_LOG_LEVEL_WRN is not set
CONFIG_ESB_LOG_LEVEL_INF=y
# CONFIG_ESB_LOG_LEVEL_DBG is not set
CONFIG_ESB_LOG_LEVEL=3
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_ALERTS is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL=3
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# end of Debug
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
# CONFIG_PARTITION_MANAGER_ENABLED is not set
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_ADP536X is not set
# CONFIG_AT_MONITOR is not set
# CONFIG_DISABLE_FLASH_PATCH is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CUSTOM_CMD is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_MODEM_SLM is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_ENTROPY_CC3XX=y
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_BH1749 is not set
# CONFIG_SENSOR_SIM is not set
# CONFIG_SENSOR_STUB is not set
# CONFIG_PMW3360 is not set
# CONFIG_PAW3212 is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=8
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.3.0/nrf)
# hostap (C:/ncs/v2.3.0/modules/lib/hostap)
CONFIG_POSIX_MAX_FDS=4
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (C:/ncs/v2.3.0/modules/lib/hostap)
# mcuboot (C:/ncs/v2.3.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.3.0/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.3.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# end of mbedtls (C:/ncs/v2.3.0/modules/crypto/mbedtls)
# trusted-firmware-m (C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
# cjson (C:/ncs/v2.3.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.3.0/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.3.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.3.0/modules/lib/azure-sdk-for-c)
# memfault-firmware-sdk (C:/ncs/v2.3.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.3.0/modules/lib/memfault-firmware-sdk)
# cirrus-logic (C:/ncs/v2.3.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.3.0/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.3.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.3.0/modules/lib/openthread)
# canopennode (C:/ncs/v2.3.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.3.0/modules/lib/canopennode)
# chre (C:/ncs/v2.3.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.3.0/modules/lib/chre)
# fatfs (C:/ncs/v2.3.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.3.0/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.3.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
# CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED is not set
# CONFIG_NRFX_COMP is not set
CONFIG_NRFX_EGU=y
CONFIG_NRFX_EGU0=y
CONFIG_NRFX_EGU1=y
CONFIG_NRFX_EGU2=y
CONFIG_NRFX_EGU3=y
CONFIG_NRFX_EGU4=y
CONFIG_NRFX_EGU5=y
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
CONFIG_NRFX_POWER=y
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SYSTICK is not set
CONFIG_NRFX_TEMP=y
CONFIG_NRFX_TIMER=y
CONFIG_NRFX_TIMER0=y
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_TIMER2=y
CONFIG_NRFX_TIMER3=y
CONFIG_NRFX_TIMER4=y
CONFIG_NRFX_TWI=y
CONFIG_NRFX_TWI0=y
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_UART0 is not set
# CONFIG_NRFX_UARTE1 is not set
CONFIG_NRFX_USBD=y
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v2.3.0/modules/hal/nordic)
# liblc3 (C:/ncs/v2.3.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.3.0/modules/lib/liblc3)
# littlefs (C:/ncs/v2.3.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.3.0/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.3.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.3.0/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.3.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.3.0/modules/lib/gui/lvgl)
# lz4 (C:/ncs/v2.3.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.3.0/modules/lib/lz4)
# nanopb (C:/ncs/v2.3.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.3.0/modules/lib/nanopb)
# picolibc (C:/ncs/v2.3.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.3.0/modules/lib/picolibc)
# TraceRecorder (C:/ncs/v2.3.0/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (C:/ncs/v2.3.0/modules/debug/TraceRecorder)
# uoscore-uedhoc (C:/ncs/v2.3.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.3.0/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.3.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v2.3.0/modules/lib/zcbor)
# zscilib (C:/ncs/v2.3.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.3.0/modules/lib/zscilib)
# appcore (C:/Users/dougl/git/nRF52/app/Traquito/../../lib)
CONFIG_ZEPHYR_APPCORE_MODULE=y
# end of appcore (C:/Users/dougl/git/nRF52/app/Traquito/../../lib)
# nrfxlib (C:/ncs/v2.3.0/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_CRYPTOCELL_CC310_USABLE=y
CONFIG_CRYPTOCELL_USABLE=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
# CONFIG_HW_CC3XX_INTERRUPT is not set
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.3.0/nrfxlib)
# connectedhomeip (C:/ncs/v2.3.0/modules/lib/matter)
# CONFIG_CHIP is not set
# CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.3.0/modules/lib/matter)
# Optional modules. Make sure they're installed, via the project manifest.
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_DSP is not set
# CONFIG_CMSIS_NN is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCBOR is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# end of Modules
CONFIG_BOARD_REVISION="$BOARD_REVISION"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_NRF52840CORE=y
# Board Options
# CONFIG_BOARD_ENABLE_DCDC is not set
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAMC20 is not set
# CONFIG_SOC_SERIES_SAMC21 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_RTC2=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TIMER3=y
CONFIG_HAS_HW_NRF_TIMER4=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_UART0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_SOC_NRF52840=y
# CONFIG_SOC_NRF52805_CAAA is not set
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
# CONFIG_SOC_NRF52832_QFAA is not set
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QIAA is not set
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_STACK_GUARD=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_HW_STACK_PROTECTION is not set
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
# CONFIG_BOOT_BANNER is not set
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
CONFIG_INSTRUMENT_THREAD_SWITCHING=y
CONFIG_THREAD_RUNTIME_STATS=y
# CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
CONFIG_SCHED_THREAD_USAGE=y
# CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
CONFIG_SCHED_THREAD_USAGE_ALL=y
CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
CONFIG_PIPES=y
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
# end of General Kernel Options
# Device Options
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_LORA is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
CONFIG_ETH_INIT_PRIORITY=80
# CONFIG_MDIO is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
CONFIG_UART_LOG_LEVEL_INF=y
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_LINE_CTRL=y
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
CONFIG_UART_0_NRF_UART=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_INTERRUPT_DRIVEN=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
# CONFIG_UART_1_NRF_ASYNC_LOW_POWER is not set
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UART_PERIPHERAL=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# Interrupt Controllers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
CONFIG_INTC_LOG_LEVEL_INF=y
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL=3
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer Drivers
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
CONFIG_ENTROPY_LOG_LEVEL_INF=y
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_SHELL is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
CONFIG_GPIO_NRFX=y
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
CONFIG_FXL6408_LOG_LEVEL_INF=y
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL=3
# CONFIG_SDHC is not set
CONFIG_I2C_SHELL=y
# CONFIG_I2C_CALLBACK is not set
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
CONFIG_I2C_0_NRF_TWI=y
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
CONFIG_I2C_LOG_LEVEL_INF=y
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL=3
# CONFIG_I3C is not set
# CONFIG_I2S is not set
# CONFIG_DAI is not set
CONFIG_PWM=y
# CONFIG_PWM_LOG_LEVEL_OFF is not set
# CONFIG_PWM_LOG_LEVEL_ERR is not set
# CONFIG_PWM_LOG_LEVEL_WRN is not set
CONFIG_PWM_LOG_LEVEL_INF=y
# CONFIG_PWM_LOG_LEVEL_DBG is not set
CONFIG_PWM_LOG_LEVEL=3
CONFIG_PWM_INIT_PRIORITY=50
CONFIG_PWM_SHELL=y
# CONFIG_PWM_CAPTURE is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
CONFIG_WDT_DISABLE_AT_BOOT=y
# CONFIG_WDT_LOG_LEVEL_OFF is not set
# CONFIG_WDT_LOG_LEVEL_ERR is not set
# CONFIG_WDT_LOG_LEVEL_WRN is not set
CONFIG_WDT_LOG_LEVEL_INF=y
# CONFIG_WDT_LOG_LEVEL_DBG is not set
CONFIG_WDT_LOG_LEVEL=3
CONFIG_WDT_NRFX=y
# CONFIG_W1 is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
CONFIG_CLOCK_CONTROL_NRF_SHELL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
CONFIG_FLASH_LOG_LEVEL_INF=y
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL=3
CONFIG_FLASH_SHELL=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
CONFIG_SOC_FLASH_NRF_UICR=y
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# CONFIG_SENSOR_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_LOG_LEVEL_WRN is not set
CONFIG_SENSOR_LOG_LEVEL_INF=y
# CONFIG_SENSOR_LOG_LEVEL_DBG is not set
CONFIG_SENSOR_LOG_LEVEL=3
CONFIG_SENSOR_INIT_PRIORITY=90
CONFIG_SENSOR_SHELL=y
# CONFIG_SENSOR_SHELL_BATTERY is not set
# CONFIG_SENSOR_INFO is not set
# Device Drivers
CONFIG_TEMP_NRF5=y
CONFIG_TMP112_FULL_SCALE_RUNTIME=y
CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_UDC_DRIVER is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=2048
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
# CONFIG_USB_NATIVE_POSIX is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
CONFIG_USB_DRIVER_LOG_LEVEL_INF=y
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
CONFIG_USB_DRIVER_LOG_LEVEL=3
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
CONFIG_HWINFO_LOG_LEVEL_INF=y
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL=3
CONFIG_HWINFO_SHELL=y
CONFIG_HWINFO_NRF=y
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# CONFIG_SYSCON is not set
# CONFIG_BBRAM is not set
# CONFIG_FPGA is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
CONFIG_PINCTRL_LOG_LEVEL_INF=y
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_MBOX is not set
# CONFIG_MM_DRV is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
CONFIG_USBC_LOG_LEVEL_INF=y
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_FUEL_GAUGE is not set
# C Library
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_SUPPORT_MINIMAL_LIBC=y
CONFIG_PICOLIBC_SUPPORTED=y
# CONFIG_PICOLIBC is not set
CONFIG_NEWLIB_LIBC=y
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# Additional libraries
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_CRC=y
# CONFIG_CRC_SHELL is not set
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
CONFIG_SYS_HEAP_SMALL_ONLY=y
# CONFIG_SYS_HEAP_BIG_ONLY is not set
# CONFIG_SYS_HEAP_AUTO is not set
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
CONFIG_GETOPT=y
# CONFIG_GETOPT_LONG is not set
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
CONFIG_FNMATCH=y
# end of Util libraries
# CONFIG_SMF is not set
# end of Additional libraries
# Sub Systems and OS Services
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
CONFIG_CPLUSPLUS=y
# CONFIG_STD_CPP98 is not set
# CONFIG_STD_CPP11 is not set
# CONFIG_STD_CPP14 is not set
# CONFIG_STD_CPP17 is not set
# CONFIG_STD_CPP2A is not set
CONFIG_STD_CPP20=y
# CONFIG_STD_CPP2B is not set
# CONFIG_CPP_MAIN is not set
CONFIG_LIB_CPLUSPLUS=y
# CONFIG_RTTI is not set
CONFIG_CPP_STATIC_INIT_GNU=y
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
CONFIG_DEBUG=y
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
# CONFIG_EARLY_CONSOLE is not set
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
CONFIG_DEBUG_INFO=y
CONFIG_EXCEPTION_STACK_TRACE=y
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
CONFIG_NVS=y
# CONFIG_NVS_LOOKUP_CACHE is not set
# CONFIG_NVS_LOG_LEVEL_OFF is not set
# CONFIG_NVS_LOG_LEVEL_ERR is not set
# CONFIG_NVS_LOG_LEVEL_WRN is not set
CONFIG_NVS_LOG_LEVEL_INF=y
# CONFIG_NVS_LOG_LEVEL_DBG is not set
CONFIG_NVS_LOG_LEVEL=3
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# Logging
CONFIG_LOG=y
# CONFIG_LOG_MODE_DEFERRED is not set
CONFIG_LOG_MODE_IMMEDIATE=y
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
CONFIG_LOG_FUNC_NAME_PREFIX_ERR=y
CONFIG_LOG_FUNC_NAME_PREFIX_WRN=y
CONFIG_LOG_FUNC_NAME_PREFIX_INF=y
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
# CONFIG_LOG_IMMEDIATE_CLEAN_OUTPUT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_SWO is not set
CONFIG_LOG_BACKEND_UART=y
# CONFIG_LOG_BACKEND_UART_ASYNC is not set
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG_CMDS=y
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_ALWAYS_RUNTIME=y
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
# CONFIG_DSP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
# CONFIG_NET_BUF is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Portability
# end of Portability
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
CONFIG_PM_LOG_LEVEL_INF=y
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL=3
# CONFIG_PM_S2RAM is not set
CONFIG_PM_POLICY_DEFAULT=y
# CONFIG_PM_POLICY_CUSTOM is not set
# end of Power Management
CONFIG_SHELL=y
# CONFIG_SHELL_LOG_LEVEL_OFF is not set
# CONFIG_SHELL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_LOG_LEVEL_WRN is not set
CONFIG_SHELL_LOG_LEVEL_INF=y
# CONFIG_SHELL_LOG_LEVEL_DBG is not set
CONFIG_SHELL_LOG_LEVEL=3
CONFIG_SHELL_BACKENDS=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=0
CONFIG_SHELL_PROMPT_UART="uart:~$ "
CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
# CONFIG_SHELL_BACKEND_SERIAL_CHECK_DTR is not set
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
# CONFIG_SHELL_BACKEND_DUMMY is not set
# CONFIG_SHELL_MINIMAL is not set
# CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
CONFIG_SHELL_STACK_SIZE=2048
CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
CONFIG_SHELL_CMD_BUFF_SIZE=256
CONFIG_SHELL_PRINTF_BUFF_SIZE=30
CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
CONFIG_SHELL_ARGC_MAX=20
CONFIG_SHELL_TAB=y
CONFIG_SHELL_TAB_AUTOCOMPLETION=y
CONFIG_SHELL_WILDCARD=y
CONFIG_SHELL_ECHO_STATUS=y
# CONFIG_SHELL_START_OBSCURED is not set
CONFIG_SHELL_VT100_COMMANDS=y
CONFIG_SHELL_VT100_COLORS=y
# CONFIG_SHELL_GETOPT is not set
CONFIG_SHELL_METAKEYS=y
CONFIG_SHELL_HELP=y
CONFIG_SHELL_HELP_OPT_PARSE=y
CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
CONFIG_SHELL_HISTORY=y
CONFIG_SHELL_HISTORY_BUFFER=512
CONFIG_SHELL_STATS=y
CONFIG_SHELL_CMDS=y
CONFIG_SHELL_CMDS_RESIZE=y
# CONFIG_SHELL_CMDS_SELECT is not set
CONFIG_SHELL_CMD_ROOT=""
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y
CONFIG_KERNEL_SHELL=y
CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
CONFIG_DEVICE_SHELL=y
CONFIG_DEVMEM_SHELL=y
# CONFIG_STATS is not set
CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
CONFIG_USB_DEVICE_LOG_LEVEL_INF=y
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_USB_DEVICE_LOG_LEVEL=3
CONFIG_USB_DEVICE_VID=0x2FE3
CONFIG_USB_DEVICE_PID=0x0008
CONFIG_USB_DEVICE_MANUFACTURER="Traquito"
CONFIG_USB_DEVICE_PRODUCT="Traquito"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_COMPOSITE_DEVICE is not set
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
# CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT is not set
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL_INF=y
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL=3
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# CONFIG_USB_DEVICE_BT_H4 is not set
# CONFIG_USB_DEVICE_LOOPBACK is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USBC_STACK is not set
# CONFIG_SD_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_IMG_MANAGER is not set
# Random Number Generators
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRING_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# Storage
# CONFIG_FLASH_MAP is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_SETTINGS is not set
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_RTIO is not set
# CONFIG_ZBUS is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_15=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
CONFIG_BUILD_OUTPUT_UF2=y
CONFIG_BUILD_OUTPUT_UF2_FAMILY_ID="0xada52840"
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# CONFIG_LEGACY_INCLUDE_PATH is not set
Can you tell me how to prevent this from happening deterministically?
Or detect that it has happened so my code can take some corrective action (what?)?
This error seized up my device and it is not sufficient to (for example) just tweak a buffer and hope the problem doesn't happen again.
Thanks.
