Setting up Sidewalk SDK
I am trying to install/setup the sidewalk repository according to instructions here: https://nrfconnect.github.io/sdk-sidewalk/setting_up_sidewalk_environment/setting_up_sdk.html.  I have already installed the nRF Connect SDK via the “Toolchain Manager” method.
But at step #4, it failed at (c), "Verify the new manifest path". Please help me out. The error messages captured below:
$ west manifest --path
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 2380, in _import_content_from_project
content = _manifest_content_at(project, path)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 185, in _manifest_content_at
out = project.git(['ls-tree', rev, path], capture_stdout=True,
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 845, in git
raise subprocess.CalledProcessError(popen.returncode, cmd_list,
subprocess.CalledProcessError: Command '['ls-tree', 'refs/heads/manifest-rev', 'west.yml']' returned non-zero exit status 128.
During handling of the above exception, another exception occurred:
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\app\project.py", line 534, in do_run
manifest = Manifest.from_topdir(topdir=self.topdir)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 1100, in from_topdir
return Manifest(topdir=topdir, config=config,
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 1396, in __init__
self._load_validated()
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 1791, in _load_validated
self._load_projects(manifest_data, url_bases, defaults)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 2114, in _load_projects
self._import_from_project(project, imp)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 2293, in _import_from_project
self._import_path_from_project(project, _WEST_YML)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 2310, in _import_path_from_project
imported = self._import_content_from_project(project, path)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 2391, in _import_content_from_project
content = self._ctx.project_importer(project, path)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\manifest.py", line 164, in _default_importer
raise ManifestImportFailed(project, file)
west.manifest.ManifestImportFailed: ManifestImportFailed: project <Project nrf ('D:\\DevTools\\ncs\\v2.3.0\\nrf') at v2.3.0> value west.yml
File "runpy.py", line 193, in _run_module_as_main
File "runpy.py", line 86, in _run_code
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Scripts\west.exe\__main__.py", line 7, in <module>
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\app\main.py", line 793, in main
app.run(argv or sys.argv[1:])
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\app\main.py", line 109, in run
self.run_command(argv)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\app\main.py", line 342, in run_command
cmd.run(args, unknown, self.topdir, manifest=self.manifest,
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\commands.py", line 135, in run
self.do_run(args, unknown)
File "D:\DevTools\ncs\toolchains\v2.3.0\opt\bin\Lib\site-packages\west\app\project.py", line 538, in do_run
log.die(f"manifest import failed\n Project: {mif.project}\n "
AttributeError: 'ManifestImportFailed' object has no attribute 'filename'
