We are observing a crash in BLE samples provided by Zephyr/Nordic which occurs after calling bt_enable(). It is clear that the issue is in the hci_core.c when bt_init() is called. bt_init() calls hci_init() which calls common_init() which fails in the first bt_hci_cmd_send_sync() call when the take of the sync_sem fails after HCI_CMD_TIMEOUT which is 10 seconds.
As a sanity check, we tried using the Zephyr controller on our board, an nRF52833DK, and an nRF52840DK.
We tried enabling the Zephyr controller on our application, the direct adv sample, and the HR central sample.
All fail 10s after attempting bt_init() for the same reason.
The bt samples work as expected using the Softdevice controller.
BT related KCONFIG changed in BT samples and our application to switch to Zephyr BLE controller:
CONFIG_BT_LL_SW_SPLIT=y
BT related KCONFIGs enabled in our app:
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SCAN=y
CONFIG_BT_CTLR=y
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
BT related KCONFIGs enabled for samples kept the same aside from the BT_LL_SW_SPLIT
NCS Version: nrf connect SDK v2.2.0
Zephyr Version: zephyr-sdk-0.15.1
We have also attempted rolling back to NCS versions:
v2.2.0, v2.3.0, v1.9.2 and v1.5.0
