how to change Esim profile for nbiot fall back
I'm using nrf9160custom board using sdk version 2.0.0
our Esim has 2 profiles one is for LTE and another one is for NB-IoT. Present i have tested tested LTE network and its working fine but i need to work on NB-IoT.
i have no idea how to do fallback for LTE to NB-IoT.
our Esim provider given fallback APDU command.
i have refered below document too but i don't have any how to send AT+CSIM command
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fref_at_commands%2FREF%2Fat_commands%2Faccess_uicc%2Faccess_uicc.html
Thank you
  • Hi
    To begin with, it might be a good idea to just verify that you can attach to the NB-IoT network, by only enabling NB-IoT with AT%XSYSTEMMODE=0,1,0,0
    in my code its already configured when LTE not available its automatically changing to nb-iot
    please see the below logs
    [00:07:39.458,343] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,0,0
    11:28:19.213 -> +CEREG: 2
    11:28:20.242 -> [00:08:13.738,037] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2
    11:28:20.242 ->
    11:28:20.242 -> [00:08:13.738,128] <err> lte_lc: Could not get tracking area code, error: -22
    11:28:20.242 -> [00:08:13.738,189] <err> lte_lc: Failed to parse notification (error -22): +CEREG: 2
    11:28:20.242 ->
    11:28:38.644 -> %CESQ: 36,1,7,1
    11:28:38.644 -> +CEREG: 2,"C2F0","00273265",9
    11:28:38.644 -> LTE cell changed: Cell ID: 2568805, Tracking area: 49904
    11:28:39.622 -> [00:08:33.144,134] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"C2F0","00273265",9
    11:28:39.622 ->
    11:28:41.776 -> %CESQ: 34,1,0,0
    11:28:41.962 -> +CSCON: 1
    11:28:41.962 -> RRC mode: Connected
    11:28:42.149 -> %CESQ: 35,1,5,0
    11:28:42.149 -> +CEREG: 2,"C2F0","00273265",9,0,15
    11:28:42.196 -> +CSCON: 0
    11:28:42.196 -> RRC mode: Idle
    11:28:42.616 -> %CESQ: 255,0,255,0
    11:28:42.616 -> +CEREG: 2
    11:28:42.942 -> [00:08:36.482,147] <dbg> lte_lc.at_handler: +CSCON notification
    11:28:42.989 -> [00:08:36.700,225] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"C2F0","00273265",9,0,15
    11:28:42.989 ->
    11:28:42.989 -> [00:08:36.741,516] <dbg> lte_lc.at_handler: +CSCON notification
    11:28:42.989 -> [00:08:37.156,555] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2
    11:28:42.989 ->
    11:28:42.989 -> [00:08:37.156,646] <err> lte_lc: Could not get tracking area code, error: -22
    11:28:42.989 -> [00:08:37.156,707] <err> lte_lc: Failed to parse notification (error -22): +CEREG: 2
    11:28:42.989 ->
    11:28:43.084 -> %CESQ: 37,1,8,1
    11:29:00.636 ->
    Thank you
  • > AT+CSIM=14,80C2000009D3070202018110017D
    According AT+CSIM Docu, the length is "The number of hexadecimal characters.". So it's rather 28 than 14. And the value is a string using "". I guess, it should be
    AT+CSIM=28,"80C2000009D3070202018110017D"
    Thanks for the replay,
    i have tried this method in LTE link monitor
    when i send AT+CSIM=28,"80C2000009D3070202018110017D" below is the response logs  and LTE is show like in below
    +CSIM: 4,"980A"
    OK
    AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    %CESQ: 34,1,18,2
    +CGEV: ME PDN DEACT 0
    AT+CGDCONT?
    +CEREG: 0
    +CIND: "service",0
    +CIND: "roam",0+
    CGEV: ME DETACH
    OK
    AT+CGACT?
    OK
    +CEREG: 2,"05D7","019C4600",7
    AT+CESQ
    +CESQ: 99,99,255,255,17,35
    OK
    +CGEV: ME PDN ACT 0,0
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CEREG: 5,"05D7","019C4600",7,,,"00000001","01011111"
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","eapn1.net","100.108.4.22",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    +CNEC_ESM: 27,1
    when i send AT+CSIM=28,"80C2000009D3070202018110017C" below is the response logs  and LTE is showing Green.
    +CSIM: 4,"9809"
    OK
    AT+CESQ
    OK
    %CESQ: 35,1,19,2
    AT+CGDCONT?
    +CEREG: 0
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: ME DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","eapn1.net","100.108.4.62",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    +CGEV: ME PDN ACT 1
    AT
    +CGDCONT?
    +CGDCONT: 1,"IP","i-smsr.net","100.65.192.6",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    +CGACT: 1,1
    OK
    +CGEV: ME PDN DEACT 1
    +CNEC_ESM: 36,1
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    please check the both logs and let me know is profile switching happening or not for NB-IoT and LTE-M
    Thank you
  • > +CEREG: 2,"05D7","019C4600",7
    AFAIK the "7" means LTE-M/CAT-M1. A "9" would be NB-IoT.
    In that case E-sim not switching the profile right ?
    whats may the solution to switch the e-sim profile or need to send any command  for NB-IoT after switching the e-sim profile?
    Thank you
