how to change Esim profile for nbiot fall back
I'm using nrf9160custom board using sdk version 2.0.0
our Esim has 2 profiles one is for LTE and another one is for NB-IoT. Present i have tested tested LTE network and its working fine but i need to work on NB-IoT.
i have no idea how to do fallback for LTE to NB-IoT.
our Esim provider given fallback APDU command.
i have refered below document too but i don't have any how to send AT+CSIM command
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fref_at_commands%2FREF%2Fat_commands%2Faccess_uicc%2Faccess_uicc.html
Thank you
  • Your previous log from yesterday contains:
    > +CEREG: 2,"C2F0","00273265",9
    with that your device was connecting to NB-IoT.
    I don't know, how you setup your device. Therefore I don't know, what goes wrong or not nor what is required.
    My comment was mainly, that AT+CSIM has documentation and you didn't comply with that.
  • Hi sir,
    This logs i got from my  code in code i have already written NB-IoT fallback for physical sim but now i'm trying same thing for E-sim.
    But now i'm trying in LTE link monitor.
    After sending AT+CSIM  command how i can could whether e-sim profile changed or not.
    if it changed, i need to send AT%XSYSTEMMODE=0,1,0,0 to enable the NB-IoT ?
    for more clarity im send my fallback function when im using physical sim card please check it.
    static void lteConnect(void)
        int err = NBIOT_ERROR_OK;
        if ((err = lte_lc_connect_async(lte_handler)) != NBIOT_ERROR_OK)
            printk("Modem could not be configured, error: %d\n", err);
            err = NBIOT_ERROR_MODEM_CONFIG;
            errorHandler_process(err);
        err = k_sem_take(&lte_connected_sem, K_SECONDS(CONFIG_LTE_NETWORK_TIMEOUT));
        if (err == -EAGAIN)
            printk("LTE connection could not be established within timeout. "
                   "Schedule another attempt after sleeping\n");
            scheduleLTEReconnect(
                lte_reconnection_delay_s[atomic_get(&lte_reconnection_attempts)]);
            /*  get the current sytem mode from api and fallback */
            int error = NBIOT_ERROR_OK;
            error     = lte_lc_system_mode_get(&get_sys_mode_current);
            printk("Got mode %d \n", get_sys_mode_current);
            if (!error)
                if (get_sys_mode_current == LTE_LC_SYSTEM_MODE_NBIOT)
                    /* increment atomic variable to get the retry count of lte */
                    atomic_inc(&lte_try_count);
                    /*  Set the values in data structure to send to aws with fw
                     * info*/
                    sensor_config.nbt_try_count = atomic_get(&nbt_try_count);
                    sensor_config.lte_try_count = atomic_get(&lte_try_count);
                    // sprintf(sensor_config.nw_mode, "lte");
                    sensor_config.network_mode = NETWORK_MODE_LTE;
                    printk("Current mode is NB-IoT and changing it to LTE-CAT1 : "
                           "count of LTE-M: %d\n",
                           atomic_get(&lte_try_count));
                    /*  Set the fallback MODE to LTE */
                    int result = lte_lc_system_mode_set(LTE_LC_SYSTEM_MODE_LTEM);
                    if (!result)
                        printk("Set mode done\n");
                        /*  Sleep for a while just to give some time to change mode
                         Not given in Documantation but trial and error  */
                        k_msleep(5000);
                else if (get_sys_mode_current == LTE_LC_SYSTEM_MODE_LTEM)
                    atomic_inc(&nbt_try_count);
                    // sprintf(sensor_config.nw_mode, "nbt");
                    printk("Current mode is LTE-CAT1 and changing it to NB-IoT : "
                           "count of nbiot %d\n",
                           atomic_get(&nbt_try_count));
                    /*  Set the fallback MODE to NB-IoT */
                    int result = lte_lc_system_mode_set(LTE_LC_SYSTEM_MODE_NBIOT);
                    if (!result)
                        k_msleep(5000);
            /* Switch off modem until next reconnection attempt */
            modem_offline();
            return;
        /* Setup Power Saving Mode */
        if ((err = setup_psm()) != NBIOT_ERROR_OK)
        return;
    now i have added AT+CSIM command in this function to switch the profile which fall back is happening
    char nb_iot[] = "AT+CSIM=28,\"80C2000009D3070202018110017D\"";
    int err =at_cmd_write(nb_iot,NULL,0,NULL);
    printf("err:%d\n",err);
    but still its not connecting to NB-IoT . let me if need anything to add in code or need to add any configuration
    Thank you
  • , could you take a modem trace, where you try to change the SIM profile and connect to NB-IoT?
    we are using nrf9160 custom board can you guide how to take modem trace logs in custom board.
    In my board UART0 has UART to USB cable to see logs. how can i take modem trace using UART0?
    i have enabled "CONFIG_BSD_LIBRARY_TRACE_ENABLED=y" in prj.config
    below is my uart .dts
    &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    	tx-pin = <29>;
    	rx-pin = <28>;
    &uart1 {
    	status = "okay";
    	tx-pin = <13>;
    	rx-pin = <14>;
    	rts-pin = <0xFFFFFFFF>;
    	cts-pin = <0xFFFFFFFF>;
    char lte_m[] = "AT+CSIM=28,\"80C2000009D3070202018110017C\"";
    int err=at_cmd_write(lte_m,NULL,0,NULL);
    when i call this function im getting err=-8; may i know what it means?
    thank you
    Note that for NCS v2.0.0, you should use CONFIG_NRF_MODEM_LIB_TRACE_ENABLED, not CONFIG_BSD_LIBRARY_TRACE_ENABLED.
    The trace backend is hardcoded to use UART1, so the easiest way to get the trace over UART is to just swap the pins between UART1 and UART0. That way, they trace will come over the correct pins, and you don't have to change anything else than the pin assignment in the device tree.
    Which SDK version are you using?
    That function is deprecated, and had already been removed in NCS v2.0.0
