Using fds to store name of BLE device in NVM
I am currently working on storing the custom name of a BLE device into the internal NVM on the nrf52832 using the fds. I initialize the fds in the peer manager and see it goes through successfully so that is all good. The issue occurs when I go to store and/or read the device name after "storing" it. I will attach my up to date code to see if you see anything I am not seeing.
FYI BluetoothData.device name is a character array with a length of 12.
case APP_BLE_NAME_CHANGE_EVENT:
            //NOTE: this will fully trust AP always passes correct characters and length to the gauge
            dataPtr++; //increment our pointer to skip the space before ascii characters
            memcpy(BluetoothData.device_name,dataPtr,DEVICE_NAME_SIZE);
            // Set up record.
            record.file_id = FILE_ID;
            record.key = RECORD_KEY;
            record.data.p_data = &BluetoothData.device_name;
            record.data.length_words = (sizeof(BluetoothData.device_name) + 3) / 4;; /* one word is four bytes. */
            ret_code_t rc;
            rc = fds_record_write(&record_desc, &record);
                if (rc != NRF_SUCCESS)
                  /* Handle error. */
And here is where I attempt to read the record from memory where the name should be stored.
char * attributeGetDeviceNamePtr(void)
    static char Gauge_Name[13];
    memset(&ftok, 0x00, sizeof(fds_find_token_t));
    /* Loop until all records with the given key and file ID have been found. */
    while (fds_record_find(FILE_ID, RECORD_KEY, &record_desc, &ftok) == NRF_SUCCESS)
      if (fds_record_open(&record_desc, &flash_record) != NRF_SUCCESS)
        /* Handle error. */
      /* Access the record through the flash_record structure. */
      memcpy(Gauge_Name,flash_record.p_data,DEVICE_NAME_SIZE);
      /* Close the record when done. */
      if (fds_record_close(&record_desc) != NRF_SUCCESS)
          /* Handle error. */
    return (char *)(&Gauge_Name);
