I2C Communication Loss
Hello everyone,
I am having a random I2C communication failure.
There are two things that communicate. One is master which is nRF52840 and the other is ADS7128.
Those two ICs on different boards and the communication goes over differential I2C IC (PCA9616).
I attached the schematics for both sides.
And the problem is, we lose communication randomly sometimes for a short time sometimes for a long time like hours even days.
In the code, we reinit the I2C if it fails but we don't do any error check.
On the Nordic side, there are two 2.2k pull-ups. Below is the code from driver's side.
// Registers
#define REG_SYSTEM_STATUS   0x00
#define REG_GENERAL_CFG     0x01
#define REG_DATA_CFG        0x02
#define REG_OSR_CFG         0x03
#define REG_OPMODE_CFG      0x04
#define REG_PIN_CFG         0x05
#define REG_GPIO_CFG        0x07
#define REG_GPO_DRIVE_CFG   0x09
#define REG_SEQUENCE_CFG    0x10
#define REG_CHANNEL_SEL     0x11
#define REG_AUTO_SEQ_CH_SEL 0x12
#define REG_RMS_CFG         0xC0
#define REG_RMS_LSB         0xC1
#define REG_RMS_MSB         0xC2
#define REG_MAX_CH0_LSB     0x60
#define REG_MIN_CH0_LSB     0x80
#define REG_RECENT_CH0_LSB  0xA0
#define CURRENT_DEFAULT_FREQUENCY         16.0f
#define CURRENT_DEFAULT_MEDIAN_WINDOW     3
#define CURRENT_DEFAULT_MEDIAN_REMOVE     1
#define CURRENT_DEFAULT_LOWPASS_ORDER     2
#define CURRENT_DEFAULT_LOWPASS_FREQUENCY 4.0f
#define CURRENT_DEFAULT_DECIMATION        2
#define CURRENT_DEFAULT_PRECISION         12
INIT_SAMPLER(current, CHANNEL_CURRENT, 1, NULL, NULL, NULL);
// Multiply by that to convert to uV
// gain = 3.3V * 1000000 uV/V / 65536 LSB = 50.354 uV / LSB
#define GAIN_NUM_UV         19487
#define GAIN_DEN_UV         387
#define SAMPLE_LSB_TO_UV(s) (( ((uint32_t) (s)) * GAIN_NUM_UV) / GAIN_DEN_UV)
enum {
    CONFIG_MODE_AUTOSEQUENCE,
    //CONFIG_MODE_RMS_SWITCHED_AC,
    CONFIG_MODE_RMS_CURRENT
static bool adsConfigDone = false;
static uint8_t adsConfigMode = 0;
static uint32_t adsConfigTicks = 0;
#define MONITOR_PERIOD_MS       1000
#define MONITOR_SAMPLE_DELAY_MS 40
static bool monitorEnabled;
static TimerHandle_t monitorTimerHandle;
static StaticTimer_t monitorTimer;
QUEUE_STATIC_DECLARATION(monitorTipSwik, 1, sizeof(int32_t));
QUEUE_STATIC_DECLARATION(monitorDc5V, 1, sizeof(int32_t));
//QUEUE_STATIC_DECLARATION(monitorControlFET, 1, sizeof(int32_t));
QUEUE_STATIC_DECLARATION(monitorCurrent, 1, sizeof(uint32_t));
QUEUE_STATIC_DECLARATION(monitorSSRVoltage, 1, sizeof(uint32_t));
QUEUE_STATIC_DECLARATION(monitorControlPostFET, 1, sizeof(int32_t));
// ======== TWI RELATED STUFF ========
//0x10 is what we use/want, addr is tied to gnd, which isn't defined by datasheet, but 0x10 seems to b default
#define ADS_ADDRESS 0x10
// Define TWI instance that we'll be using
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(ADS_TWI_INSTANCE);
static bool twi_initialized = false;
#define TWI_NUMBER_TRIES_MAX   1
#define TWI_DEFAULT_TIMEOUT_US 1000
#define TWI_DELAY_BEFORE_US    50
#if TWI_DELAY_BEFORE_US > 0
#define TWI_DELAY_BEFORE_FCT   nrf_delay_us(TWI_DELAY_BEFORE_US)
#else
static volatile bool twi_failure = false;
static volatile bool twi_done = false;
static uint8_t i2cBuffer[32];
static void ads_twi_handler(nrf_drv_twi_evt_t const *event, void *context) {
    twi_done = true;
    twi_failure = (event->type != NRF_DRV_TWI_EVT_DONE);
static void ads_twi_init(void) {
    //NRF_LOG_INFO("twi init");
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ADS_SCL_PIN,
       .sda                = ADS_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW,
       .clear_bus_init     = true
    // Initialize TWI instance with config
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, ads_twi_handler, NULL);
    // Enable instance
    nrf_drv_twi_enable(&m_twi);
    if (err_code == NRF_SUCCESS) {
        twi_initialized = true;
    } else {
        NRF_LOG_INFO("ads_twi_init failure");
static void ads_twi_uninit(void) {
    nrf_drv_twi_disable(&m_twi);
    nrf_drv_twi_uninit(&m_twi);
static void ads_twi_retry(void) {
    if (twi_initialized && twi_failure) {
        ads_twi_uninit();
    if (!twi_initialized) {
        ads_twi_init();
// Function to write data to ADS
static void ads_write(uint8_t const * data, uint8_t len, bool nostop) {
    if (twi_initialized && !twi_failure) {
        for (uint8_t nTry = 0; nTry < TWI_NUMBER_TRIES_MAX; ++nTry) {
            twi_done = false;
            err_code = nrf_drv_twi_tx(&m_twi, ADS_ADDRESS, data, len, nostop);
            if (err_code != 0) {
                twi_done = true;
                twi_failure = true;
                //NRF_LOG_INFO("w t %u r %u", nTry, err_code);
                return;
            uint16_t countdown = TWI_DEFAULT_TIMEOUT_US;
            while (!twi_done) {
                if (--countdown == 0) {
                    twi_done = true;
                    twi_failure = true;
                nrf_delay_us(1);
            if (!twi_failure) {
                return;
            } else {
                //NRF_LOG_INFO("w t %u r %u d %u f %u c %u", nTry, err_code, twi_done, twi_failure, countdown);
// Function to read data from ADS
static void ads_read(uint8_t* data, uint8_t len) {
            twi_done = false;
            err_code = nrf_drv_twi_rx(&m_twi, ADS_ADDRESS, data, len);
                twi_done = true;
                twi_failure = true;
                //NRF_LOG_INFO("r t %u r %u", nTry, err_code);
                return;
            while (!twi_done) {
                    twi_done = true;
                    twi_failure = true;
                nrf_delay_us(1);
            //NRF_LOG_INFO("r t %u r %u d %u f %u c %u", nTry, err_code, twi_done, twi_failure, countdown);
            if (!twi_failure) {
                return;
    if (twi_failure) {
        memset(data, 0, len);
ads7128 has 'opcodes' which is a layer above i2c, it seems a bit redundant to me..
so you send the addr, then the opcode, then the reg then data.
relevant opcodes:
00010000b = register read  =16
00001000b = register write
also, 7128 has 8 bit regs, instead of 16
#define OP_CODE_READ       0b00010000
#define OP_CODE_READ_MANY  0b00110000
#define OP_CODE_WRITE      0b00001000
#define OP_CODE_WRITE_MANY 0b00101000
static uint8_t adsReadRegister(uint8_t reg) {
    TWI_DELAY_BEFORE_FCT;
    i2cBuffer[0] = OP_CODE_READ;
    i2cBuffer[1] = reg;
    ads_write(i2cBuffer, 2, false);
    ads_read(i2cBuffer, 1);
    return i2cBuffer[0];
static uint16_t adsReadRegister2(uint8_t reg) {
    i2cBuffer[0] = OP_CODE_READ_MANY;
    i2cBuffer[1] = reg;
    ads_read(i2cBuffer, 2);
    return ((uint16_t)i2cBuffer[0]) | (((uint16_t)i2cBuffer[1] << 8));
static void adsWriteRegister(uint8_t reg, uint8_t value) {
    i2cBuffer[0] = OP_CODE_WRITE;
    i2cBuffer[1] = reg;
    i2cBuffer[2] = value;
    ads_write(i2cBuffer, 3, false);
static void adsSetConfig(uint8_t newConfigMode, bool uninit) {
    if (uninit) {
        if (twi_initialized) {
            ads_twi_uninit();
    //NRF_LOG_INFO("Set config %u", newConfigMode);
    // Try again
    ads_twi_retry();
    switch (newConfigMode) {
        case CONFIG_MODE_AUTOSEQUENCE:
            // Set all analog io, STATS disabled to erase MIN and MAX registers
            adsWriteRegister(REG_GENERAL_CFG,     0b00000100);
            // all io set as analog in
            adsWriteRegister(REG_PIN_CFG,         0b00000000);
            // Only enable the used channels
            adsWriteRegister(REG_AUTO_SEQ_CH_SEL, 0b11010101);
            // Enable sequencing mode
            adsWriteRegister(REG_SEQUENCE_CFG,    0b00000001);
            // Enable autonomous mode, with sequencing
            // Clock to 1 MHz
            adsWriteRegister(REG_OPMODE_CFG,      0b00100000);
            // Average 128x
            adsWriteRegister(REG_OSR_CFG,         0b00000111);
            // Enable DWC
            adsWriteRegister(REG_GENERAL_CFG,     0b00110100);
            // Start the sequencer / sampling
            adsWriteRegister(REG_SEQUENCE_CFG,    0b00010001);
        //case CONFIG_MODE_RMS_SWITCHED_AC:
        case CONFIG_MODE_RMS_CURRENT:
            uint8_t channel = ADS_CHANNEL_CURRENT;
            // Channel mask
            adsWriteRegister(REG_AUTO_SEQ_CH_SEL, 0b00000001 << channel);
            // No average
            adsWriteRegister(REG_OSR_CFG,         0b00000000);
            // Clock to 1 MHz
            // Set RMS module, 16384 samples for 16ms, DC component removed
            adsWriteRegister(REG_RMS_CFG,         (channel << 4) | 0b00000110);
            // Enable DWC, enable RMS
            adsWriteRegister(REG_GENERAL_CFG,     0b10110100);
            // Clear RMS done flag
            adsWriteRegister(REG_SYSTEM_STATUS,   0b00010000);
    if (twi_failure) {
        //NRF_LOG_INFO("Config Failure");
    } else {
        adsConfigDone = true;
        adsConfigMode = newConfigMode;
        adsConfigTicks = xTaskGetTickCount();
static int32_t adsReadSample(uint8_t channel, uint8_t regBase, uint16_t* sample) {
    uint8_t lsbReg = regBase + 2*channel;
    *sample = adsReadRegister2(lsbReg);
    return twi_failure? -1 : 0;
static int32_t adsReadRms(uint16_t* sample) {
    uint8_t systemStatus = adsReadRegister(REG_SYSTEM_STATUS);
    if (!twi_failure && (systemStatus & 0b00010000)) {
        *sample = adsReadRegister2(REG_RMS_LSB);
        return 0;
    NRF_LOG_INFO("rms invalid %u %u %u", twi_failure, systemStatus, adsConfigMode);
    return -1;
void currentCallback(TimerHandle_t timer) {
    uint32_t ticksElapsed = xTaskGetTickCount() - adsConfigTicks;
    int16_t sample = SAMPLE_INVALID;
    if (!adsConfigDone || adsConfigMode != CONFIG_MODE_RMS_CURRENT || ticksElapsed < pdMS_TO_TICKS(20)) {
        if (adsConfigDone && adsConfigMode == CONFIG_MODE_RMS_CURRENT) {
            //NRF_LOG_INFO("/!\\ ADS CONFIG %u /!\\", ticksElapsed);
        adsSetConfig(CONFIG_MODE_RMS_CURRENT, false);
    } else {
        ads_twi_retry();
        //NRF_LOG_INFO("ticks %u", ticksElapsed);
        uint16_t reading16;
        int32_t reading32;
        int32_t err_code = adsReadRms(&reading16);
        if (err_code >= 0) {
            reading32 = ((int32_t) reading16) * 2 - 32768;
            if (reading32 > SAMPLE_VALID_MAX) {
                sample = SAMPLE_VALID_MAX;
            } else if (reading32 < SAMPLE_VALID_MIN) {
                sample = SAMPLE_VALID_MIN;
            } else {
                sample = reading32;
#if DEBUG_PRINT_AVERAGE
            static int32_t TEST_counter = 0;
            static int32_t TEST_sum = 0;
            for (uint8_t i = 0; i < currentSampler.numberReads; ++i) {
                TEST_sum += reading;
            ++TEST_counter;
            if (TEST_counter == currentSampler.frequency) {
                int32_t average = TEST_sum / TEST_counter / currentSampler.numberReads;
                //int32_t average_uV = average * gainValues_uV;
                NRF_LOG_INFO("Current average: %d", average);
                TEST_counter = 0;
                TEST_sum = 0;
    // Reset the sampler if needed
    if (currentSampler.mustEmptyRaw) {
        samplerEmptyRaw(&currentSampler);
    if (timeIsValid() && !currentSampler.blockRaw) {
        // Process a timestamp if needed
        if (samplerNeedTimestamp(&currentSampler)) {
            timeMs_t time;
            timeGetCurrent(&time);
            samplerAddTimestamp(&currentSampler, &time);
        // Add the sample
        samplerAddSamples(&currentSampler, &sample); //, xTaskGetTickCount());
static void monitorCallback(TimerHandle_t timer) {
    static uint32_t cycle_counter = 0;
    //uint32_t tickCount = xTaskGetTickCount();
    //NRF_LOG_INFO("1 %09u", tickCount);
    if (!monitorEnabled) {
        // Reset the cycle
        cycle_counter = 0;
        return;
    uint8_t monitorConfigMode = 0; //(cycle_counter/2) % 2;
    if (cycle_counter % 2 == 0) {
        //NRF_LOG_INFO("2 %09u", tickCount + pdMS_TO_TICKS(MONITOR_SAMPLE_DELAY_MS));
        // Time to set the config to the proper mode
        if (!adsConfigDone || adsConfigMode != monitorConfigMode) {
            adsSetConfig(monitorConfigMode, monitorConfigMode == 0);
        // This function should also start the timer
        xTimerChangePeriod(monitorTimerHandle, pdMS_TO_TICKS(MONITOR_SAMPLE_DELAY_MS), 0);
    } else {
        if (adsConfigDone && adsConfigMode == monitorConfigMode) {
            ads_twi_retry();
            // Add the correct sample to the queue
            switch (monitorConfigMode) {
                    int32_t err_code;
                    uint16_t reading;
                    uint16_t readingMin;
                    uint16_t readingMax;
                    uint32_t sample_uV;
                    err_code = adsReadSample(ADS_CHANNEL_TIP_SWIK, REG_RECENT_CH0_LSB, &reading);
                        sample_uV = SAMPLE_LSB_TO_UV(reading);
                        xQueueOverwrite(monitorTipSwikQueueHandle, &sample_uV);
                        //NRF_LOG_INFO("Tip Swik        %04d %07d", reading, sample_uV);
                    //NRF_LOG_INFO("%u %d %d", twi_failure, reading, sample_uV);
                    err_code = adsReadSample(ADS_CHANNEL_DC_5V, REG_RECENT_CH0_LSB, &reading);
                        sample_uV = 2 * SAMPLE_LSB_TO_UV(reading);
                        xQueueOverwrite(monitorDc5VQueueHandle, &sample_uV);
                        behaviorSetState(BEHAVIOR_MODE_5V_CONTROL, (sample_uV > 4000000)? BEHAVIOR_STATE_TRUE : BEHAVIOR_STATE_FALSE);
                        //NRF_LOG_INFO("DC 5V           %04d %07d", reading, sample_uV);
                    err_code = adsReadSample(ADS_CHANNEL_CONTROL_POST_FET, REG_RECENT_CH0_LSB, &reading);
                        xQueueOverwrite(monitorControlPostFETQueueHandle, &sample_uV);
                        //NRF_LOG_INFO("ControlPostFET  %04d %07d", reading, sample_uV);
                    err_code = adsReadSample(ADS_CHANNEL_SWITCHED_AC, REG_MIN_CH0_LSB, &readingMin);
                    err_code |= adsReadSample(ADS_CHANNEL_SWITCHED_AC, REG_MAX_CH0_LSB, &readingMax);
                        // Rms = (max - min) / (2*sqrt(2))
                        sample_uV = SAMPLE_LSB_TO_UV(readingMax - readingMin) * 204 / 577;
                        xQueueOverwrite(monitorSSRVoltageQueueHandle, &sample_uV);
                        //NRF_LOG_INFO("Min %u Max %u", readingMin, readingMax);
                    err_code = adsReadSample(ADS_CHANNEL_CURRENT, REG_MIN_CH0_LSB, &readingMin);
                    err_code |= adsReadSample(ADS_CHANNEL_CURRENT, REG_MAX_CH0_LSB, &readingMax);
                        // * 2000 / 66.5          (sensor coupling ratio, measurement resistor)
                        sample_uV = SAMPLE_LSB_TO_UV(readingMax - readingMin) * 319 / 30;
                        xQueueOverwrite(monitorCurrentQueueHandle, &sample_uV);
                        //NRF_LOG_INFO("Min %u Max %u RMS %u", readingMin, readingMax, sample_uV);
                /*case CONFIG_MODE_RMS_CURRENT:
                    uint16_t rms;
                    int32_t err_code = adsReadRms(&rms);
                        if (rms < 0) {
                            rms = 0;
                        uint32_t rms_uA = SAMPLE_LSB_TO_UV(rms) * 30;
                        xQueueOverwrite(monitorCurrentQueueHandle, &rms_uA);
        // Back to the proper mode
        currentMonitorSetBehavior(true);
    ++cycle_counter;
bool currentGetLastTipSwikValue(bool erase, uint32_t* sample_uV) {
    if (erase) {
        return xQueueReceive(monitorTipSwikQueueHandle, sample_uV, 0) == pdTRUE;
    return xQueuePeek(monitorTipSwikQueueHandle, sample_uV, 0) == pdTRUE;
bool currentGetLastDc5VValue(bool erase, uint32_t* sample_uV) {
    if (erase) {
        return xQueueReceive(monitorDc5VQueueHandle, sample_uV, 0) == pdTRUE;
    return xQueuePeek(monitorDc5VQueueHandle, sample_uV, 0) == pdTRUE;
bool currentGetLastControlFETValue(bool erase, int32_t* sample_uV) {
    if (erase) {
        return xQueueReceive(monitorControlFETQueueHandle, sample_uV, 0) == pdTRUE;
    return xQueuePeek(monitorControlFETQueueHandle, sample_uV, 0) == pdTRUE;
bool currentGetLastCurrentValue(bool erase, uint32_t* sample_uA) {
    if (erase) {
        return xQueueReceive(monitorCurrentQueueHandle, sample_uA, 0) == pdTRUE;
    return xQueuePeek(monitorCurrentQueueHandle, sample_uA, 0) == pdTRUE;
bool currentGetLastSSRVoltageValue(bool erase, uint32_t* sample_uV) {
    if (erase) {
        return xQueueReceive(monitorSSRVoltageQueueHandle, sample_uV, 0) == pdTRUE;
    return xQueuePeek(monitorSSRVoltageQueueHandle, sample_uV, 0) == pdTRUE;
bool currentGetLastControlPostFETValue(bool erase, uint32_t* sample_uV) {
    if (erase) {
        return xQueueReceive(monitorControlPostFETQueueHandle, sample_uV, 0) == pdTRUE;
    return xQueuePeek(monitorControlPostFETQueueHandle, sample_uV, 0) == pdTRUE;
void currentMonitorSetBehavior(bool enabled) {
    monitorEnabled = enabled;
    if (enabled) {
        if (xTimerIsTimerActive(currentSampler.timerHandle) != pdFALSE) {
            // Current timer is active, be careful with the timing
            // We want to wake up the monitor timer in more than MONITOR_PERIOD_MS
            // But we should also leave room for 2*MONITOR_SAMPLE_DELAY_MS + some safety margin
            // There must not be any sampler expiry time between ticksStart and ticksEnd
            uint32_t ticks = xTaskGetTickCount();
            uint32_t samplerNextExpiry = xTimerGetExpiryTime(currentSampler.timerHandle);
            uint32_t samplerPeriod = xTimerGetPeriod(currentSampler.timerHandle);
            uint32_t dt = ticks + pdMS_TO_TICKS(MONITOR_PERIOD_MS) - samplerNextExpiry;
            uint32_t k = (dt < 0x80000000) * (dt / samplerPeriod + 1);
            //NRF_LOG_INFO("3 %09u", samplerNextExpiry + k*samplerPeriod + 5);
            xTimerChangePeriod(monitorTimerHandle, samplerNextExpiry + k*samplerPeriod - ticks + 5, 0);
        } else {
            xTimerChangePeriod(monitorTimerHandle, pdMS_TO_TICKS(MONITOR_PERIOD_MS), 0);
sampler_t* currentInit(void) {
    //NRF_LOG_INFO("Current init sampler size: %u bytes, frequency: %u Hz", sizeof(sampler_t), currentSampler.frequency);
    // Initialize I2C communication
    QUEUE_STATIC_DEFINITION(monitorTipSwik);
    QUEUE_STATIC_DEFINITION(monitorDc5V);
    //QUEUE_STATIC_DEFINITION(monitorControlFET);
    QUEUE_STATIC_DEFINITION(monitorCurrent);
    QUEUE_STATIC_DEFINITION(monitorSSRVoltage);
    QUEUE_STATIC_DEFINITION(monitorControlPostFET);
    // function to initialize the timer task, expires after 2 milliseconds and does not auto-reload
    monitorTimerHandle = xTimerCreateStatic(
        "monitorTimer",
        pdFALSE,
        (void *) (0),
        monitorCallback,
        &monitorTimer);
    // Initialize load cell by creating sampler
    samplerInit(&currentSampler, currentCallback);
    samplerInitParams(&currentSampler, CURRENT_DEFAULT_FREQUENCY, CURRENT_DEFAULT_MEDIAN_WINDOW, CURRENT_DEFAULT_MEDIAN_REMOVE,
        CURRENT_DEFAULT_LOWPASS_ORDER, CURRENT_DEFAULT_LOWPASS_FREQUENCY,
        CURRENT_DEFAULT_DECIMATION, CURRENT_DEFAULT_PRECISION);
    return &currentSampler;
  • How do you wire this system? Does it embedded in a PCB, or is it a mesh of prototype components/modules?
    Also  - what is the error code?
  • What exactly do you mean how do I wire the system? They are separate devices and I connect them with 8 pin cable.
    There are two different devices in two different boxes and they are connected with a cable.
    And the physical protocol differential I2C. You can see the IC that I used from the above schematic.
    Add: Since I don't debug the firmware for now, I don't know the error code. If I can not find anything on the hardware side, I will check the firmware. I am planning to write a special code for logging the communication.
  • I think you should check your cables and connectors - I got a lot of I2C and SPI communication issues due to bad wiring. If your code works sometimes and sometimes not - your lines are to blame for communication errors. Try to get them in a tight position and a moist-free environment, and you'll probably get way smoother communication :)
    The error code I tried to refer to was 0x0BAE0001, which implicitly refers to what I said as the source of the issue.
    In general - put as many logs on crucial points( In the nRF5 SDK, it was almost a built-in function, I think), and it will save you a lot of time!
