nRF Terminal no longer works after nRF Terminal extension update
System details:
- Ubuntu Linux version 20.04.6 LTS
- nRF Connect for Desktop v4.0.1
- Toolchain Manager v1.2.2
- NCS v2.2.0
- Visual Studio Code 1.77.3
There has been a new update for nRF Terminal extension see here:
https://nrfconnect.github.io/vscode-nrf-connect/release_notes/terminal/2023.4.15.html
Since this new update, I no longer have any output in terminal.
I tried the hello world example with the NRF52840DK kit which has always worked for me. But now it no longer works.
I can connect to the DK board, but there is no output. Also no errors.
I usually select Actions - Debug
Then under Connected Devices - RTT I click on the Connect to RTT symbol (on the right).
Since this new update, it no longer works.
The release notes suggest to add a serial terminal by pressing the + in the Tab Terminal.
I tried:
nRF RTT Terminal
nRF Serial Terminal
But every time I get a prompt to manually enter all the details of the serial connection. I get no suggestions in the input text field (on the release note page it does show COM port suggestions).
I have to enter stuff like:
- Enter device
- Enter serial number
- Choose memory address
- Select port
- Enter port path
- Choose configuration
Also there is no option anymore to gracefully terminate the connection to the J-Link. I used this a lot because terminal connection tasks got hanging in the background and new terminals would no longer work if this is the case.
[15:55:07] nrfutil [682896]: s2 { id: '683245598', capabilities: { rtt: true, erase: true, recover: true }, device: { id: 11, jlink: [Object], serialNumber: '000683245598', serialPorts: [Array], traits: [Object], usb: [Object] } }
[15:55:20] sh -c west flash -d /home/user/vscode/hello_world/buildNordicDK --skip-rebuild --dev-id 683245598
[15:55:35] Success.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "linux",
    "osVersion": "#164-Ubuntu SMP Tue Mar 21 14:23:17 UTC 2023",
    "osKernel": "5.4.0-147-generic",
    "vscode": "1.77.3",
    "electron": "19.1.11",
    "node": "v16.14.2"
  "system": {
    "date": "2023-05-02T14:02:57.869Z",
    "vscodeRoot": "/usr/share/code/resources/app",
    "nrfConnectForDesktopInstalled": "unknown",
    "vscodeUptime": "00:07:56",
    "osUptime": "126:00:20",
    "cpu": {
      "model": "Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz",
      "speed": "700 MHz",
      "count": 4
    "memory": {
      "total": "15.40 GB",
      "free": "2.47 GB"
  "workspace": {
    "name": "hello_world",
    "workspaceFile": null,
    "folders": [
      "/home/user/vscode/hello_world"
  "extensions": {
    "internal": {
        "version": "2023.4.179",
        "path": "/home/user/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.4.179-linux-x64",
        "isActive": true
        "version": "2023.4.15",
        "path": "/home/user/.vscode/extensions/nordic-semiconductor.nrf-terminal-2023.4.15",
        "isActive": true
        "version": "2023.4.61",
        "path": "/home/user/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2023.4.61",
        "isActive": true
        "version": "2023.4.17",
        "path": "/home/user/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2023.4.17",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.10.0",
      "ms-vscode.cpptools": "1.15.4",
      "ms-vscode.js-debug": "1.77.2",
      "ms-vscode.js-debug-companion": "1.0.18",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.20",
      "mcu-debug.rtos-views": "0.0.6",
      "twxs.cmake": "0.0.17",
      "utsavm9.c-cpp-flag-debugging": "0.0.1"
  "tools": {
    "/home/user/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.0",
    "/opt/SEGGER/JLink/JLinkExe": "6.88a",
    "/usr/local/bin/nrfjprog": "10.17.2",
    "/home/user/.local/bin/nrfutil": null,
    "/home/user/.local/bin/cmake": "3.24.1",
    "/home/user/.local/bin/west": "0.13.1",
    "/usr/bin/python3": "3.8.10",
    "/usr/bin/ninja": "1.10.0",
    "/usr/bin/gperf": "3.1",
    "/usr/bin/dtc": "1.5.0",
    "gn": "Not found",
    "/usr/bin/git": "2.25.1",
    "gdbPath": "/home/user/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
  "sdks": [
      "version": "2.1.2",
      "path": "/home/user/ncs2/v2.1.2"
      "version": "2.4.99",
      "path": "/home/user/zephyrproject"
      "version": "2.2.0",
      "path": "/home/user/ncs2/v2.2.0"
  "toolchains": [
      "version": "2.1.2",
      "path": "/home/user/ncs2/toolchains/v2.1.2"
      "version": "2.2.0",
      "path": "/home/user/ncs2/toolchains/v2.2.0"
  "connectedDevices": [
      "serialNumber": "000683245598",
      "boardVersion": "PCA10056",
      "deviceFamily": "NRF52_FAMILY",
      "deviceVersion": "NRF52840_xxAA_REV2",
      "jlinkObFirmwareVersion": "J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31"
  "deviceProvider": "nrfutil",
  "config": {
      "topdir": "${nrf-connect.sdk:2.2.0}",
      "toolchain": {
        "path": "PATH"
      "ozonePath": "",
      "applications": [
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true,
      "taskBindings": {},
      "debugging": {
        "backend": "nRF Debug",
        "flash": true,
        "bindings": {}
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "armToolchainPath": "/home/user/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin",
      "armToolchainPrefix": "arm-zephyr-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": "/opt/SEGGER/JLink/JLinkGDBServerCLExe",
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "/home/user",
      "PATH": "/home/user/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin:/tmp/.mount_nrfcon6rDHiE:/tmp/.mount_nrfcon6rDHiE/usr/sbin:/home/user/.local/bin:/home/user/.local/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin",
      "ZEPHYR_BASE": "/home/user/ncs2/v2.2.0/zephyr",
      "USER": "user"
    "inherited": {
      "PATH": "/tmp/.mount_nrfcon6rDHiE:/tmp/.mount_nrfcon6rDHiE/usr/sbin:/home/user/.local/bin:/home/user/.local/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin",
      "ZEPHYR_BASE": "/home/user/ncs2/v2.2.0/zephyr/",
      "USER": "user"
    "toolchainPath": "PATH"
  "terminal": {
    "shell": null,
    "defaultProfile": null
    What output did you have before? Was this tested with the Hello World sample as well?
    I tested with the default Hello World sample on a nRF5340DK. This samples does not have logging enabled and thus does not provide any output when connecting to RTT.
    Adding the following to prj.conf did provide RTT output
    CONFIG LOG=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    Øyvind
