hello Nordic
i am using nrf52832 and nrf52840, working with ncs v2.1.2
i wish to compress data packets that are sent via BLE to reduce the transmitted data size.
i saw there is lz4 implementation in the ncs, i tried to use the example at /zephyr/samples/compression/lz4/
since i got less then 10% compression, (and since i don't think speed will be an issue cause reading the data chunks from flash takes much longer then the compression) i tried to use more compress oriented API
const int src_size = (int)(strlen(src) + 1);
const int max_dst_size = LZ4_compressBound(src_size);
char *compressed_data = malloc((size_t)max_dst_size);
if (compressed_data == NULL) {
LOG_INF("Failed to allocate memory for compressed data\n");
return;
LOG_INF("src ptr before %p, %p", (int*)src, src);
int srcptr = 0;
const int compressed_data_size = LZ4_compress_destSize(src, compressed_data, &srcptr, 256);
// const int compressed_data_size = LZ4_compress_default(src,
// compressed_data, src_size,
// max_dst_size);
if (compressed_data_size <= 0) {
LOG_INF("Failed to compress the data\n");
return;
LOG_INF("-----------------------ZIV-------------------------\n");
LOG_INF("src ptr after %d,srcptr);
LOG_INF("Original Data size: %d\n", src_size);
LOG_INF("planned compres size %d\n", max_dst_size);
LOG_INF("Compressed Data size : %d\n", compressed_data_size);
compressed_data = (char *)realloc(compressed_data,
(size_t)compressed_data_size);
LOG_INF("Failed to re-alloc memory for compressed data\n");
return;
char * const decompressed_data = malloc(src_size);
if (decompressed_data == NULL) {
LOG_INF("Failed to allocate memory to decompress data\n");
return;
const int decompressed_size = LZ4_decompress_safe(compressed_data,
decompressed_data, compressed_data_size,
src_size);
if (decompressed_size < 0) {
LOG_INF("Failed to decompress the data\n");
return;
free(compressed_data);
if (decompressed_size >= 0) {
LOG_INF("Successfully decompressed some data\n");
if (decompressed_size != src_size) {
LOG_INF("Decompressed data is different from original decompress size %d, src size %d\n", decompressed_size, src_size);
return;
if (memcmp(src, decompressed_data, src_size) != 0) {
LOG_INF("Validation failed.\n");
LOG_INF("*src and *new_src are not identical\n");
return;
LOG_INF("Validation done. The string we ended up with is:\n%s\n",
decompressed_data);
// for ( int i = 0; i< 512; ++i)
// LOG_INF("%d,", decompressed_data[i]);
LOG_INF("------------------------ZIV------------------------\n");
but its or i am not using it right or it is not so efficient with target size of 200, with target size of 256 a little bit better, but maybe it is more relevant to the type of data in each area, i am not sure.. also if there is an optimal size to compress to .. (i add the prints below the code part)
00> [00000000] <inf> MAIN: -----------------------ZIV------------------------- 00> 00> [00000000] <inf> MAIN: src ptr after 0 00> [00000000] <inf> MAIN: Original Data size: 512 00> 00> [00000000] <inf> MAIN: planned compres size 530 00> 00> [00000000] <inf> MAIN: Compressed Data size : 1 00> 00> [00000000] <inf> MAIN: Successfully decompressed some data 00> 00> [00000000] <inf> MAIN: Decompressed data is different from original decompress size 0, src size 512
why srcPtr does not change ?
what am i missing?
i also saw there is a module in the ncs lz4hc that is supposed to be more compression oriented then speed but not sure how to use it, is there some example or guide on that ?
also there is lzio, lz4frame, lz4frame_static, lz77 , lz4hc, compress_Frame_Fuzzer, compress_hc_Fuzzer, is there some guide to which strength each of them brings, and how to use ?
(i know lz77 is the father of the family, and hc means high compression but that's it)
hope to read you soon
best regards
Ziv
