I am using nrf5340dk board with NCS 2.3.
I have taken the USB Mass Storage example and am trying to configure it to work over spi with an 8miby NOR JEDEC flash.
The external flash appears to be correctly read by the spi-nor driver including the JEDEC parameters.
When I first connect to a windows pc the drive appears to only have 64kb of space. If I then use windows to format the drive to 8mb then it appears correctly and I can add files and folders.
However, if I eject the device and reconnect it, then it again shows up as having 64kb and all of the files and folders are gone.
In code I can use the zephyr file system api to create a folder on the flash that will persist over powercycles, so I believe the flash device is working correctly.
I have simplified the mass storage example to do nothing other than start the USB.
Below are is the start up output, my config file and the overlay file I am using to configure things.
[00:00:00.251,983] <inf> spi_nor: is25: SFDP v 1.6 AP ff with 1 PH
[00:00:00.258,911] <inf> spi_nor: PH0: ff00 rev 1.6: 16 DW @ 30
[00:00:00.265,686] <inf> spi_nor: is25: 8 MiBy flash
*** Booting Zephyr OS build v3.2.99-ncs2 ***
[00:00:00.275,451] <inf> flashdisk: Initialize device NAND
[00:00:00.281,585] <inf> flashdisk: offset 0, sector size 512, page size 65536, volume size 8388608
[00:00:00.291,656] <inf> usb_msc: Sect Count 16384
[00:00:00.297,088] <inf> usb_msc: Memory Size 8388608
[00:00:01.303,039] <inf> main: The device is put in USB mass storage mode.
CONFIG_STDOUT_CONSOLE=n CONFIG_DEBUG=y CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_NO_OPTIMIZATIONS=y CONFIG_LOG=y CONFIG_LOG_MODE_IMMEDIATE=y CONFIG_LOG_OVERRIDE_LEVEL=2 CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y #USB related configs CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="Zephyr MSC sample" CONFIG_USB_DEVICE_PID=0x0008 CONFIG_LOG=y CONFIG_USB_DRIVER_LOG_LEVEL_INF=y CONFIG_USB_MASS_STORAGE=y CONFIG_USB_DEVICE_LOG_LEVEL_INF=y CONFIG_USB_MASS_STORAGE_LOG_LEVEL_INF=y CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n CONFIG_MAIN_STACK_SIZE=4096 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=4096 CONFIG_USB_WORKQUEUE_STACK_SIZE=4096 CONFIG_MASS_STORAGE_STACK_SIZE=4096 #CONFIG_MAIN_STACK_SIZE=1536 CONFIG_DISK_DRIVER_FLASH=y ##jxl added #CONFIG_FLASH=y CONFIG_FLASH_JESD216_API=y CONFIG_FLASHDISK_LOG_LEVEL_INF=y #CONFIG_DISK_DRIVER_SDMMC=y CONFIG_SPI=y CONFIG_NRFX_SPIM3=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8 CONFIG_MULTITHREADING=y CONFIG_SPI_NOR_SFDP_RUNTIME=y CONFIG_SPI_NOR=y CONFIG_NORDIC_QSPI_NOR=n CONFIG_APP_MSC_STORAGE_FLASH_FATFS=y ##trials and error #CONFIG_USB_WORKQUEUE=y
* Copyright (c) 2020 Nordic Semiconductor ASA
&qspi{
status = "disabled";
&pinctrl {
spi3_default: spi3_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 1, 6)>,
<NRF_PSEL(SPIM_MISO, 1, 9)>,
<NRF_PSEL(SPIM_MOSI, 1, 7)>;
spi3_sleep: spi3_sleep {
group1 {
low-power-enable;
&spi3{
status = "okay";
cs-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi3_default>;
pinctrl-1 = <&spi3_sleep>;
is25: is25lp064d@0 {
compatible = "jedec,spi-nor";
status="okay";
label = "is25";
reg = <0>;
spi-max-frequency = <8000000>; // Max frequency achievable with nRF5340 at 64Mhz //
size = <67108864>; // Size in bit set to 1 Gb (128 MBytes) //
jedec-id = [9d 60 17];
partitions {
#address-cells = <1>;
#size-cells = <1>;
mass_storage_partition: partition@0 {
label = "mass_storage";
reg = <0x00000000 0x0800000>;
aliases {
spi-flash0 = &is25;
msc_disk0 {
compatible = "zephyr,flash-disk";
partition = <&mass_storage_partition>;
disk-name = "NAND";
cache-size = <65536>;
I wonder if you are able to help me understand what is going on?
Justin
