Network stability debug help
We are running into an issue of stability with our LTE connection. Our nRF9160 makes a call every 5 minutes to our backend. On start-up, the device connects and starts making these calls.  After some time (90 minutes to 3 days) we stop seeing the communication to our backend. Once we power cycle the device, we start to see the calls coming in again. The 9160 application has the watchdog enabled, and is not hanging as I'm still seeing heartbeat print outs on RTT viewer.
I'm getting the system setup to collect the modem trace files with nRF Connect Trace Collector. Are there any additional debug outputs I should be collecting to help diagnose this network connection issue?
We're using:
NVS v2.1.2
MFW v1.3.3
Zephyr 3.1.99
On ATT network
    All logs along with modem traces are good for us to look into. Make sure that the logs correspond with the modem traces. What kind of application are you running on your device? Are you running this on custom HW or our development kit nRF9160DK?
    Thanks.
    Øyvind
    Following up on this ticket. We've updated our code a good amount since the original posting, but are seeing possibly the same issue.
    We are seeing an issue where our LTE data stops reaching our backend. From the RTT viewer prints, the nRF9160 dropped the network connection for a period of ~70 minutes before reconnecting. We didn't have a trace being collected for this, but I've setup a test board with trace capture running to catch this.
    We have a custom board that has a nRF9160 and a nRF5340. POST and GET commands are sent from the 5340 via UART to the 9160, and the 9160 returns data from the calls to the 5340. To save battery, we suspend our UART peripherals on both IC's when not in use, then have shared GPIO act as a wakeup when one of the IC's has data to send over UART. We use the zephyr ‘pm_device_action_run()’ function to suspend and resume the UART peripherals.
    I will post a modem trace once it's captured, but in the meantime we're wondering 1.) if there are any known issues, or additional areas we should look into regarding the 9160 disconnecting from the network, and 2.) are there any known issues with the UART peripherals on either the 9160 or 5340 that could prevent them from exiting low power mode?
    nRF9160, nRF5340
    NCS v2.4.0
    MFW v1.3.5
    AT&T SIM
  • Hi, sorry for the late reply.
    Difficult to tell without modem traces. I'm not aware of any issues. AT command CEREG might have more information on reject cause (contains an EPS Mobility Management (EMM) cause value. See 3GPP TS 24.301 Annex A and EMM cause value. See 3GPP TS 24.301 Annex A).
    Not that I'm aware of. Will need to know more about your applications on both the nRF9160 and the nRF5350.
    Øyvind
  • Hey Oyvind,
    We were able to record a modem trace when we saw our issue (attached). Are you able to have this reviewed for any issues towards the end of the file?Modem_Trace_2023.11.17.mtrace
    All the best,
    Eric
  • Hi Eric, sorry for the late reply. Have not had the time to forward this to our experts. Hope to forward/progress tomorrow or Friday.
    Øyvind
