nRF Connect SDK: ModuleNotFoundError: No module named 'encodings'
I am using the nRF Connect SDK 2.3.0 and running into an issue when calling python from the terminal opened from the Toolchain Manager (via the Open Terminal option).
Calling `python` from this terminal gives me the following error:
Python path configuration:
  PYTHONHOME = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local'
  PYTHONPATH = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local/lib/python3.8/site-packages'
  program name = 'python'
  isolated = 0
  environment = 1
  user site = 1
  import site = 1
  sys._base_executable = '/usr/bin/python'
  sys.base_prefix = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local'
  sys.base_exec_prefix = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local'
  sys.platlibdir = 'lib'
  sys.executable = '/usr/bin/python'
  sys.prefix = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local'
  sys.exec_prefix = '/home/guilherme/ncs/toolchains/v2.3.0/usr/local'
  sys.path = [
    '/home/guilherme/ncs/toolchains/v2.3.0/usr/local/lib/python3.8/site-packages',
    '/home/guilherme/ncs/toolchains/v2.3.0/usr/local/lib/python310.zip',
    '/home/guilherme/ncs/toolchains/v2.3.0/usr/local/lib/python3.10',
    '/home/guilherme/ncs/toolchains/v2.3.0/usr/local/lib/python3.10/lib-dynload',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
Current thread 0x00007f6c65212740 (most recent call first):
  <no Python frame>
If I use python3 instead of python, it works as expected. This causes me more trouble down the line because I have a west extension that uses subprocess.Popen() and I run into the exact same error trace.
What might be causing this and how do I solve the problem?
