Azure iot hub connection fails after half hour 30 min, Keepalive without effect
I want to send data to azure Iot hub less frequent than every 30 min. But after the first 30 min, messages sent by the nrf9160 won't arrive at the server. A disconnection error does not occur during that time (see Log). Disconnection error occurs if device tries to send something after the first 30 min (at 11:30:37:254 it tries to send other ping but fails).
The Log with keepalive set to 1600 sec and event interval 1800 sec: see how the first messages gets achknowledged (at 10:33:57:439) but the last message not (at 11:03:56:962) and see the successful ping (at 11:00:37:353)
10:33:49:500 -> +CEREG: 2,"57F0","02CB7D05",7
10:33:49:679 -> +CSCON: 1
10:33:49:680 -> [00:00:00.481,842] <inf> board_control: eSIM is selected
10:33:49:718 -> [00:00:00.481,872] <inf> board_control: Charger is set to auto
10:33:49:718 -> *** Booting Zephyr OS build v3.2.99-ncs2 ***
10:33:49:718 -> [00:00:00.481,964] <inf> azure_iot_hub_sample: Azure IoT Hub sample started
10:33:49:718 -> [00:00:00.482,055] <inf> azure_iot_hub_sample: Connecting to LTE network
10:33:49:718 -> [00:00:01.317,871] <inf> azure_iot_hub_sample: LTE cell changed: Cell ID: 46890245, Tracking area: 22512
10:33:49:718 -> [00:00:01.461,059] <inf> azure_iot_hub_sample: RRC mode: Connected
10:33:51:846 -> +CEREG: 5,"57F0","02CB7D05",7,,,"00001010","01011111"
10:33:52:936 -> [00:00:03.666,412] <inf> azure_iot_hub_sample: Network registration status: Connected - roaming
10:33:52:936 -> [00:00:03.666,564] <inf> azure_iot_hub_sample: Connected to LTE network
10:33:52:936 -> [00:00:03.666,564] <inf> azure_iot_hub_sample: Azure IoT Hub library initialized
10:33:52:936 -> [00:00:03.666,687] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTING
10:33:52:936 -> [00:00:03.667,846] <inf> azure_iot_hub_sample: PSM parameter update: TAU: 1116000, Active time: 20
10:33:56:354 -> [00:00:07.085,357] <inf> azure_iot_hub_sample: Connection request sent to IoT Hub
10:33:56:354 -> [00:00:07.325,103] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_CONNECTED
10:33:56:354 -> [00:00:07.556,427] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_READY
10:33:56:354 -> [00:00:07.556,732] <inf> azure_iot_hub_sample: Sending event:{"temperature":25.6,"timestamp":7556}
10:33:56:354 -> [00:00:07.557,617] <inf> azure_iot_hub_sample: Event was successfully sent
10:33:56:354 -> [00:00:07.557,617] <inf> azure_iot_hub_sample: Next event will be sent in 20 seconds
10:33:56:354 -> [00:00:07.903,808] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_TWIN_RECEIVED
10:33:56:354 -> [00:00:07.906,280] <inf> azure_iot_hub_sample: Sending event:{"temperature":25.6,"timestamp":7906}
10:33:56:354 -> [00:00:07.906,829] <inf> azure_iot_hub_sample: Event was successfully sent
10:33:56:354 -> [00:00:07.906,829] <inf> azure_iot_hub_sample: Next event will be sent in 1800 seconds
10:33:57:439 -> [00:00:08.235,382] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_PUBACK
10:33:57:439 -> [00:00:08.482,391] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_PUBACK
10:34:08:754 -> +CSCON: 0
10:34:09:771 -> [00:00:20.572,998] <inf> azure_iot_hub_sample: RRC mode: Idle
11:00:36:339 -> +CSCON: 1
11:00:37:327 -> [00:26:48.267,150] <inf> azure_iot_hub_sample: RRC mode: Connected
11:00:37:353 -> [00:26:48.573,455] <inf> azure_iot_hub_sample: AZURE_IOT_HUB_EVT_PINGRESP
11:00:37:353 ->
11:00:48:395 -> +CSCON: 0
11:00:49:408 -> [00:27:00.331,756] <inf> azure_iot_hub_sample: RRC mode: Idle
11:03:56:098 -> +CEREG: 5,"57F0","028AB802",7,,,"00001010","01011111"
11:03:56:305 -> +CSCON: 1
11:03:56:962 -> [00:30:07.907,043] <inf> azure_iot_hub_sample: Sending event:{"temperature":25.6,"timestamp":1807906}
11:03:57:015 -> [00:30:07.916,168] <inf> azure_iot_hub_sample: Event was successfully sent
11:03:57:015 -> [00:30:07.916,168] <inf> azure_iot_hub_sample: Next event will be sent in 1800 seconds
11:03:57:015 -> [00:30:08.037,384] <inf> azure_iot_hub_sample: LTE cell changed: Cell ID: 42645506, Tracking area: 22512
11:03:57:015 -> [00:30:08.241,973] <inf> azure_iot_hub_sample: RRC mode: Connected
11:04:08:329 -> +CSCON: 0
11:04:09:347 -> [00:30:20.276,489] <inf> azure_iot_hub_sample: RRC mode: Idle
To make a minimal example I took the azure_iot_hub example from NSC
  1. set the event_interval to 1800 sec in device twin.
  2. set the MQTT keepalive time to 1600 sec (instead of 1767 sec) just to be sure
  3. added the PINGRESP case to azure_event_handler() to see if pings come back
  4. Changed MQTT QoS to 1 "at least once" to see if message arrived at the server
case AZURE_IOT_HUB_EVT_PINGRESP:
	LOG_INF("AZURE_IOT_HUB_EVT_PINGRESP\n");
struct azure_iot_hub_msg msg = {
	.topic.type = AZURE_IOT_HUB_TOPIC_EVENT,
	.payload.ptr = buf,
	.qos = MQTT_QOS_1_AT_LEAST_ONCE,
	.message_id = k_cycle_get_32()
I played with the MQTT keepalive time:
- When set to 60 sec, it works flawless. The device sends a ping every minute and after 30min the message arrives at the server. Problem is that the modem wont go to sleep here -> high energy consumption
- When set to 240 sec, energy consumption is much better here, but the keepalive time is still to high to keep connection alive
Another thing I found: When event_interval is lower than 1767 sec messages arrive at the server, even if no ping was sent in the period before. That tells me, that the ping/keepalive signal has no effect on resetting timeouts in the whole connection chain. Can that be true?
Hardware: NRF9160 B2 on the actinius Icarus V2
Software: NCS 2.3.0
Thanks a lot for your help! Slight smile
Best regards, Moritz43080.prj.conf
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <stdio.h>
#include <stdlib.h>
#include <net/azure_iot_hub.h>
#include <net/azure_iot_hub_dps.h>
#include <dk_buttons_and_leds.h>
#include <cJSON.h>
#include <cJSON_os.h>
#if IS_ENABLED(CONFIG_LTE_LINK_CONTROL)
#include <modem/lte_lc.h>
LOG_MODULE_REGISTER(azure_iot_hub_sample, CONFIG_AZURE_IOT_HUB_SAMPLE_LOG_LEVEL);
/* Interval [s] between sending events to the IoT hub. The value can be changed
 * by setting a new desired value for property 'telemetryInterval' in the
 * device twin document.
#define EVENT_INTERVAL		20
#define RECV_BUF_SIZE		1024
#define APP_WORK_Q_STACK_SIZE	KB(2)
struct method_data {
	struct k_work work;
	char request_id[8];
	char name[32];
	char payload[200];
} method_data;
struct k_work twin_report_work;
struct k_work_delayable send_event_work;
static char recv_buf[RECV_BUF_SIZE];
static void direct_method_handler(struct k_work *work);
static K_SEM_DEFINE(network_connected_sem, 0, 1);
static K_SEM_DEFINE(recv_buf_sem, 1, 1);
static atomic_t event_interval = EVENT_INTERVAL;
#ifdef CONFIG_AZURE_IOT_HUB_DPS
static bool dps_was_successful;
/* A work queue is created to execute potentially blocking calls from.
 * This is done to avoid blocking for example the system work queue for extended
 * periods of time.
static K_THREAD_STACK_DEFINE(application_stack_area, APP_WORK_Q_STACK_SIZE);
static struct k_work_q application_work_q;
/* Returns a positive integer if the new interval can be parsed, otherwise -1 */
static int event_interval_get(char *buf)
	struct cJSON *root_obj, *desired_obj, *event_interval_obj;
	int new_interval = -1;
	root_obj = cJSON_Parse(buf);
	if (root_obj == NULL) {
		LOG_ERR("Could not parse properties object");
		return -1;
	/* If the incoming buffer is a notification from the cloud about changes
	 * made to the device twin's "desired" properties, the root object will
	 * only contain the newly changed properties, and can be treated as if
	 * it is the "desired" object.
	 * If the incoming is the response to a request to receive the device
	 * twin, it will contain a "desired" object and a "reported" object,
	 * and we need to access that object instead of the root.
	desired_obj = cJSON_GetObjectItem(root_obj, "desired");
	if (desired_obj == NULL) {
		desired_obj = root_obj;
	/* Update only recognized properties. */
	event_interval_obj = cJSON_GetObjectItem(desired_obj,
						 "telemetryInterval");
	if (event_interval_obj == NULL) {
		LOG_INF("No 'telemetryInterval' object in the device twin");
		goto clean_exit;
	if (cJSON_IsString(event_interval_obj)) {
		new_interval = atoi(event_interval_obj->valuestring);
	} else if (cJSON_IsNumber(event_interval_obj)) {
		new_interval = event_interval_obj->valueint;
	} else {
		LOG_WRN("Invalid telemetry interval format received");
		goto clean_exit;
clean_exit:
	cJSON_Delete(root_obj);
	k_sem_give(&recv_buf_sem);
	return new_interval;
static void event_interval_apply(int interval)
	if (interval <= 0) {
		return;
	atomic_set(&event_interval, interval);
	k_work_reschedule_for_queue(&application_work_q, &send_event_work,
				    K_NO_WAIT);
static void on_evt_twin_desired(char *buf, size_t len)
	if (k_sem_take(&recv_buf_sem, K_NO_WAIT) == 0) {
		if (len > sizeof(recv_buf) - 1) {
			LOG_ERR("Incoming data too big for buffer");
			return;
		memcpy(recv_buf, buf, len);
		recv_buf[len] = '\0';
		k_work_submit_to_queue(&application_work_q, &twin_report_work);
	} else {
		LOG_WRN("Recv buffer is busy, data was not copied");
static void on_evt_direct_method(struct azure_iot_hub_method *method)
	size_t request_id_len = MIN(sizeof(method_data.request_id) - 1, method->request_id.size);
	size_t name_len = MIN(sizeof(method_data.name) - 1, method->name.size);
	LOG_INF("Method name: %.*s", method->name.size, method->name.ptr);
	LOG_INF("Payload: %.*s", method->payload.size, method->payload.ptr);
	memcpy(method_data.request_id, method->request_id.ptr, request_id_len);
	method_data.request_id[request_id_len] = '\0';
	memcpy(method_data.name, method->name.ptr, name_len);
	method_data.name[name_len] = '\0';
	snprintk(method_data.payload, sizeof(method_data.payload),
		 "%.*s", method->payload.size, method->payload.ptr);
	k_work_submit_to_queue(&application_work_q, &method_data.work);
static void azure_event_handler(struct azure_iot_hub_evt *const evt)
	switch (evt->type) {
	case AZURE_IOT_HUB_EVT_CONNECTING:
		LOG_INF("AZURE_IOT_HUB_EVT_CONNECTING");
	case AZURE_IOT_HUB_EVT_CONNECTED:
		LOG_INF("AZURE_IOT_HUB_EVT_CONNECTED");
	case AZURE_IOT_HUB_EVT_CONNECTION_FAILED:
		LOG_INF("AZURE_IOT_HUB_EVT_CONNECTION_FAILED");
		LOG_INF("Error code received from IoT Hub: %d",
			evt->data.err);
	case AZURE_IOT_HUB_EVT_DISCONNECTED:
		LOG_INF("AZURE_IOT_HUB_EVT_DISCONNECTED");
	case AZURE_IOT_HUB_EVT_READY:
		LOG_INF("AZURE_IOT_HUB_EVT_READY");
		/* The AZURE_IOT_HUB_EVT_READY event indicates that the
		 * IoT hub connection is established and interaction with the
		 * cloud can begin.
		 * The below work submission will cause send_event() to be
		 * call after 3 seconds.
					    &send_event_work, K_NO_WAIT);
	case AZURE_IOT_HUB_EVT_DATA_RECEIVED:
		LOG_INF("AZURE_IOT_HUB_EVT_DATA_RECEIVED");
		LOG_INF("Received payload: %.*s",
			evt->data.msg.payload.size, evt->data.msg.payload.ptr);
	case AZURE_IOT_HUB_EVT_TWIN_RECEIVED:
		LOG_INF("AZURE_IOT_HUB_EVT_TWIN_RECEIVED");
		event_interval_apply(event_interval_get(evt->data.msg.payload.ptr));
	case AZURE_IOT_HUB_EVT_TWIN_DESIRED_RECEIVED:
		LOG_INF("AZURE_IOT_HUB_EVT_TWIN_DESIRED_RECEIVED");
		on_evt_twin_desired(evt->data.msg.payload.ptr, evt->data.msg.payload.size);
	case AZURE_IOT_HUB_EVT_DIRECT_METHOD:
		LOG_INF("AZURE_IOT_HUB_EVT_DIRECT_METHOD");
		on_evt_direct_method(&evt->data.method);
	case AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS:
		LOG_INF("AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS, ID: %.*s",
			evt->data.result.request_id.size, evt->data.result.request_id.ptr);
	case AZURE_IOT_HUB_EVT_TWIN_RESULT_FAIL:
		LOG_INF("AZURE_IOT_HUB_EVT_TWIN_RESULT_FAIL, ID %.*s, status %d",
			evt->data.result.request_id.ptr,
			evt->data.result.status);
	case AZURE_IOT_HUB_EVT_PUBACK:
		LOG_INF("AZURE_IOT_HUB_EVT_PUBACK");
	case AZURE_IOT_HUB_EVT_ERROR:
		LOG_INF("AZURE_IOT_HUB_EVT_ERROR");
		LOG_ERR("Unknown Azure IoT Hub event type: %d", evt->type);
static void send_event(struct k_work *work)
	int err;
	static char buf[60];
	ssize_t len;
		.payload.ptr = buf,
	len = snprintk(buf, sizeof(buf),
		       "{\"temperature\":%d.%d,\"timestamp\":%d}",
		       25, k_uptime_get_32() % 10, k_uptime_get_32());
	if ((len < 0) || (len > sizeof(buf))) {
		LOG_ERR("Failed to populate event buffer");
		goto exit;
	msg.payload.size = len;
	LOG_INF("Sending event:%s", buf);
	err = azure_iot_hub_send(&msg);
	if (err) {
		LOG_ERR("Failed to send event");
		goto exit;
	LOG_INF("Event was successfully sent");
exit:
	if (atomic_get(&event_interval) <= 0) {
		LOG_ERR("The event reporting stops, interval is set to %ld",
		       atomic_get(&event_interval));
		return;
	LOG_INF("Next event will be sent in %ld seconds", event_interval);
				    K_SECONDS(event_interval));
	int err;
	static char *response = "{\"it\":\"worked\"}";
	/* Status code 200 indicates successful execution of direct method. */
	struct azure_iot_hub_result result = {
		.request_id = {
			.ptr = method_data.request_id,
			.size = strlen(method_data.request_id),
		.status = 200,
		.payload.ptr = response,
		.payload.size = sizeof(response) - 1,
	bool led_state = strncmp(method_data.payload, "0", 1) ? 1 : 0;
	if (strcmp(method_data.name, "led") != 0) {
		LOG_INF("Unknown direct method");
		return;
#if defined(CONFIG_DK_LIBRARY)
	err = dk_set_led(DK_LED1, led_state);
	if (err) {
		LOG_ERR("Failed to set LED, error: %d", err);
		return;
#else
	LOG_INF("No hardware interface to set LED state to %d", led_state);
	err = azure_iot_hub_method_respond(&result);
	if (err) {
		LOG_ERR("Failed to send direct method response");
static void twin_report_work_fn(struct k_work *work)
	int err;
	char buf[100];
	ssize_t len;
	struct azure_iot_hub_msg data = {
		.topic.type = AZURE_IOT_HUB_TOPIC_TWIN_REPORTED,
		.payload.ptr = buf,
		.qos = MQTT_QOS_0_AT_MOST_ONCE,
	int new_interval;
	new_interval = event_interval_get(recv_buf);
	if (new_interval < 0) {
		return;
		       "{\"telemetryInterval\":%d}", new_interval);
	if (len <= 0) {
		LOG_ERR("Failed to create twin report");
		return;
	data.payload.size = len;
	err = azure_iot_hub_send(&data);
	if (err) {
		LOG_ERR("Failed to send twin report");
		return;
	/* Note that the new interval value is first applied here, because that
	 * will make the "reported" value in the device twin be in sync with
	 * the reality on the device. Other applications may decide
	 * to apply the desired properties regardless of whether the value is
	 * successfully reported or not.
	event_interval_apply(new_interval);
	LOG_INF("New telemetry interval has been applied: %d",  new_interval);
static void lte_handler(const struct lte_lc_evt *const evt)
	static bool connected;
	case LTE_LC_EVT_NW_REG_STATUS:
		if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
		    (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
			if (!connected) {
			connected = false;
			LOG_INF("LTE network is disconnected.");
			LOG_INF("Subsequent sending of data may block or fail.");
		LOG_INF("Network registration status: %s",
			evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ?
			"Connected - home network" : "Connected - roaming");
		k_sem_give(&network_connected_sem);
		connected = true;
	case LTE_LC_EVT_PSM_UPDATE:
		LOG_INF("PSM parameter update: TAU: %d, Active time: %d",
		       evt->psm_cfg.tau, evt->psm_cfg.active_time);
	case LTE_LC_EVT_EDRX_UPDATE: {
		char log_buf[60];
		ssize_t len;
		len = snprintk(log_buf, sizeof(log_buf),
			       "eDRX parameter update: eDRX: %f, PTW: %f",
			       evt->edrx_cfg.edrx, evt->edrx_cfg.ptw);
		if (len > 0) {
			LOG_INF("%s", log_buf);
	case LTE_LC_EVT_RRC_UPDATE:
		LOG_INF("RRC mode: %s",
			evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ?
			"Connected" : "Idle");
	case LTE_LC_EVT_CELL_UPDATE:
		LOG_INF("LTE cell changed: Cell ID: %d, Tracking area: %d",
			evt->cell.id, evt->cell.tac);
static void modem_configure(void)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already configured and LTE connected. */
	} else {
		int err = lte_lc_init_and_connect_async(lte_handler);
		if (err) {
			LOG_INF("Modem could not be configured, error: %d", err);
			return;
static void work_init(void)
	k_work_init(&method_data.work, direct_method_handler);
	k_work_init(&twin_report_work, twin_report_work_fn);
	k_work_init_delayable(&send_event_work, send_event);
	k_work_queue_start(&application_work_q, application_stack_area,
		       K_THREAD_STACK_SIZEOF(application_stack_area),
		       K_HIGHEST_APPLICATION_THREAD_PRIO, NULL);
#if IS_ENABLED(CONFIG_AZURE_IOT_HUB_DPS)
static K_SEM_DEFINE(dps_done_sem, 0, 1);
static void dps_handler(enum azure_iot_hub_dps_reg_status status)
	switch (status) {
	case AZURE_IOT_HUB_DPS_REG_STATUS_NOT_STARTED:
		LOG_INF("DPS registration status: AZURE_IOT_HUB_DPS_REG_STATUS_NOT_STARTED");
	case AZURE_IOT_HUB_DPS_REG_STATUS_ASSIGNING:
		LOG_INF("DPS registration status: AZURE_IOT_HUB_DPS_REG_STATUS_ASSIGNING");
	case AZURE_IOT_HUB_DPS_REG_STATUS_ASSIGNED:
		LOG_INF("DPS registration status: AZURE_IOT_HUB_DPS_REG_STATUS_ASSIGNED");
		dps_was_successful = true;
		k_sem_give(&dps_done_sem);
	case AZURE_IOT_HUB_DPS_REG_STATUS_FAILED:
		LOG_INF("DPS registration status: AZURE_IOT_HUB_DPS_REG_STATUS_FAILED");
		dps_was_successful = false;
		LOG_WRN("Unhandled DPS status: %d", status);
/* Run DPS using the provided device_id as registration ID. Upon success, the function will return
 * 0 and populate the hostname and device_id buffers with the assigned values.
 * The return value will be a negative integer in case of failure.
static int dps_run(struct azure_iot_hub_buf *hostname, struct azure_iot_hub_buf *device_id)
	int err;
	struct azure_iot_hub_dps_config dps_cfg = {
		.handler = dps_handler,
		.reg_id = {
			.ptr = device_id->ptr,
			.size = strlen(device_id->ptr),
		/* Default ID scope provided by Kconfig is used, so we will not change that. */
	LOG_INF("Starting DPS");
	err = azure_iot_hub_dps_init(&dps_cfg);
	if (err) {
		LOG_ERR("azure_iot_hub_dps_init failed, error: %d", err);
		return err;
	err = azure_iot_hub_dps_start();
	if (err == 0) {
		LOG_INF("The DPS process has started, timeout is set to %d seconds",
			CONFIG_AZURE_IOT_HUB_DPS_TIMEOUT_SEC);
		/* If DPS was started successfully, we wait for the semaphore that is given when the
		 * provisioning completes.
		(void)k_sem_take(&dps_done_sem, K_FOREVER);
		if (!dps_was_successful) {
			return -EFAULT;
		/* The device was assigned, continue to retrieve the hostname. */
	} else if (err == -EALREADY) {
		LOG_INF("Already assigned to an IoT hub, skipping DPS");
	} else {
		LOG_ERR("DPS failed to start, error: %d", err);
		return err;
	err = azure_iot_hub_dps_hostname_get(hostname);
	if (err) {
		LOG_ERR("Failed to get hostname, error: %d", err);
		return err;
	err = azure_iot_hub_dps_device_id_get(device_id);
	if (err) {
		LOG_ERR("Failed to get device ID, error: %d", err);
		return err;
	LOG_INF("Device ID \"%.*s\" assigned to IoT hub with hostname \"%.*s\"",
		device_id->size, device_id->ptr,
		hostname->size, hostname->ptr);
	return 0;
#endif /* CONFIG_AZURE_IOT_HUB_DPS && !CONFIG_AZURE_IOT_HUB_DPS_AUTO */
void main(void)
	int err;
	char device_id[128] = CONFIG_AZURE_IOT_HUB_DEVICE_ID;
	char hostname[128] = CONFIG_AZURE_IOT_HUB_HOSTNAME;
	struct azure_iot_hub_config cfg = {
		.device_id = {
			.ptr = device_id,
			.size = sizeof(CONFIG_AZURE_IOT_HUB_DEVICE_ID) - 1,
		.hostname = {
			.ptr = hostname,
			.size = sizeof(CONFIG_AZURE_IOT_HUB_HOSTNAME) - 1,
		.use_dps = true,
	LOG_INF("Azure IoT Hub sample started");
#if IS_ENABLED(CONFIG_DK_LIBRARY)
	dk_leds_init();
	work_init();
	cJSON_Init();
	LOG_INF("Connecting to LTE network");
	modem_configure();
	k_sem_take(&network_connected_sem, K_FOREVER);
	LOG_INF("Connected to LTE network");
	/* Using the device ID as DPS registration ID. */
	err = dps_run(&cfg.hostname, &cfg.device_id);
	if (err) {
		LOG_ERR("Failed to run DPS, error: %d, terminating connection attempt", err);
		return;
	err = azure_iot_hub_init(azure_event_handler);
	if (err) {
		LOG_ERR("Azure IoT Hub could not be initialized, error: %d", err);
		return;
	LOG_INF("Azure IoT Hub library initialized");
	err = azure_iot_hub_connect(&cfg);
	if (err < 0) {
		LOG_ERR("azure_iot_hub_connect failed: %d", err);
		return;
	LOG_INF("Connection request sent to IoT Hub");
	/* After the connection to the IoT hub has been established, the
	 * Azure IoT Hub library will generate events when data is received.
	 * See azure_event_handler() for which actions will be taken on the
	 * various events.
