k_timer expiry function firing multiple times in a row
I need to use timer in one of my projects.
SDK: nCS 2.3.0
Hardware: nRF52833 DK (1.0.1, 2021.37)
I have built a firmware, based on the beacon example, adding shell , ADC sampling and writing some data to flash.
Now, I want to add timer to submit some work to work queue, to sample ADC periodically.
I used k_timer API before, it worked fine, as far as I can tell. But this time, when I set it up in my code, timer expiry function gets called multiple times (4 times in a row).
Here is a snippet of the code, which is used to set up the timer:
void adc_sampling_work_handler(struct k_work *work)
    int16_t adc_mv;
    adc_mv = get_adc_measurement();
    if(adc_mv == m_adc_mv)
        return;         // Don't update
    m_adc_mv = adc_mv;
    cst_adv_data.adc1[0] = (((int16_t)m_adc_mv) >> 8) & 0xFF;
    cst_adv_data.adc1[1] = ((int16_t)m_adc_mv) & 0xFF;
    bt_le_adv_update_data(ad, ARRAY_SIZE(ad),
                    (struct bt_data*)NULL, (size_t)NULL);
K_WORK_DEFINE(adc_sampling_work, adc_sampling_work_handler);
static void adc_sampling_tim_handler(struct k_timer *timer_id)
    k_work_submit(&adc_sampling_work);
void app_timers_init(void)
    k_timer_init(&adc_sampling_timer, adc_sampling_tim_handler, NULL);
    k_timer_start(&adc_sampling_timer, K_MSEC(m_dev_cfg.tx_interval), K_MSEC(m_dev_cfg.tx_interval));
main
    /* BLE beacon init, etc. */
    app_timers_init();
I also tried implementing "work" which submits itself after k_sleep(), but I'm getting the same result.
Also tried building with nCS 2.2.0, same results.
Anyone has an idea what's going on?
Thanks
Emir
  • Hi
    I tried reproducing your issue, but I don't get duplicate messages.
    Could you share your prj.conf?
    Also, if you make a simple variable that you increment in your event handler, you can know if the event happens multiple times or if it is just logged multiple times.
    -Einar
  • Hi Einar,
    Sure, here is my prj.conf
    CONFIG_BT=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_DEVICE_NAME="Test beacon"
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_LL_SW_SPLIT=y
    CONFIG_BT_DEVICE_APPEARANCE=833
    CONFIG_BT_CTLR_ADVANCED_FEATURES=n
    CONFIG_BT_CTLR_CONN_RSSI=y
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    # Enable Shell and disable default commands
    CONFIG_SHELL=y
    CONFIG_CLOCK_CONTROL_NRF_SHELL=n
    CONFIG_SHELL_PROMPT_UART="shell:~$ "
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_STATS=n
    CONFIG_SHELL_CMDS=n
    CONFIG_KERNEL_SHELL=n
    CONFIG_SHELL_LOG_LEVEL_INF=n
    CONFIG_DEVICE_SHELL=n
    CONFIG_DEVMEM_SHELL=n
    CONFIG_LOG_CMDS=n
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_RTT=n
    CONFIG_LOG=y
    CONFIG_LOG_PRINTK=y
    CONFIG_PRINTK=y
    # Enable Flash
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
    CONFIG_FLASH_SHELL=n
    # Enable ADC
    CONFIG_ADC=y
    CONFIG_ADC_SHELL=n
    Also, I did try incrementing a variable, the first time I encountered this, and I retried now as well. The variable is incremented twice in a row, on every timer expiry for me.
    I also tested this with the shell_module sample, and I had the same issue there. I only modified the timer expiry handler in that example.
    Best regards
    Emir
  • Ok so when I copy your prj.conf I get the same behavior as you.
    But if I simply remove CONFIG_LOG_PRINTK=y and CONFIG_PRINTK=y, then I no longer get any duplicate messages.
    This is definitely an issue with how the logging is set up, I suggest you go through your prj.conf file and make sure you know what each line actually does.
    -Einar
  • Thanks for the support  It works now.
    For me, removing CONFIG_LOG_PRINTK=y and CONFIG_PRINTK=y didn't work, I still had the issue. But I did go through the prj.conf and noticed CONFIG_LOG_BACKEND_UART=y. I set it to n, and the issue was gone. (I had to disable deferred logging as well).
    Here is the resulting .conf file for reference:
    CONFIG_BT=y
    CONFIG_SHELL=y
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_CMDS=n
    CONFIG_LOG_CMDS=n
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_LOG=y
    # CONFIG_LOG_PRINTK=y
    # CONFIG_PRINTK=y
    CONFIG_LOG_MODE_DEFERRED=n
    CONFIG_LOG_MODE_IMMEDIATE=y
    # Enable Flash
    CONFIG_FLASH=y
    # Enable ADC
    CONFIG_ADC=y
    CONFIG_ADC_SHELL=n
    Thanks again for the support.
    All the best.
    Emir.
