k_timer expiry function firing multiple times in a row
I need to use timer in one of my projects.
SDK: nCS 2.3.0
Hardware: nRF52833 DK (1.0.1, 2021.37)
I have built a firmware, based on the beacon example, adding shell , ADC sampling and writing some data to flash.
Now, I want to add timer to submit some work to work queue, to sample ADC periodically.
I used k_timer API before, it worked fine, as far as I can tell. But this time, when I set it up in my code, timer expiry function gets called multiple times (4 times in a row).
Here is a snippet of the code, which is used to set up the timer:
void adc_sampling_work_handler(struct k_work *work)
    int16_t adc_mv;
    adc_mv = get_adc_measurement();
    if(adc_mv == m_adc_mv)
        return;         // Don't update
    m_adc_mv = adc_mv;
    cst_adv_data.adc1[0] = (((int16_t)m_adc_mv) >> 8) & 0xFF;
    cst_adv_data.adc1[1] = ((int16_t)m_adc_mv) & 0xFF;
    bt_le_adv_update_data(ad, ARRAY_SIZE(ad),
                    (struct bt_data*)NULL, (size_t)NULL);
K_WORK_DEFINE(adc_sampling_work, adc_sampling_work_handler);
static void adc_sampling_tim_handler(struct k_timer *timer_id)
    k_work_submit(&adc_sampling_work);
void app_timers_init(void)
    k_timer_init(&adc_sampling_timer, adc_sampling_tim_handler, NULL);
    k_timer_start(&adc_sampling_timer, K_MSEC(m_dev_cfg.tx_interval), K_MSEC(m_dev_cfg.tx_interval));
main
    /* BLE beacon init, etc. */
    app_timers_init();
I also tried implementing "work" which submits itself after k_sleep(), but I'm getting the same result.
Also tried building with nCS 2.2.0, same results.
Anyone has an idea what's going on?
Thanks
Emir
  • I just read my post again, and maybe I didn't explain well enough what's going on.
    The expiry functions is called 4 times on each expiry (the timer is a repeating timer).
  • Hello
    This leads me to believe this has nothing to do with k_timer at all, but rather with your expiry function in itself.
    Could you show me a code snippet using k_sleep like this that produces the same result?
    Einar
    thanks for the reply.
    Sure, here is the implementation I had:
        // int err;
        // int16_t adc_mv;
        // adc_mv = get_adc_measurement();
        // if(adc_mv == m_adc_mv)
        //     return;         // Don't update
        // m_adc_mv = adc_mv;
        // cst_adv_data.adc1[0] = (((int16_t)m_adc_mv) >> 8) & 0xFF;
        // cst_adv_data.adc1[1] = ((int16_t)m_adc_mv) & 0xFF;
        // bt_le_adv_update_data(ad, ARRAY_SIZE(ad),
        //                 (struct bt_data*)NULL, (size_t)NULL);
        printk("TEST\n");
        k_sleep(K_MSEC(1000));
        k_work_submit(work);
    I have also tried using k_timer_status_sync but that didn't work either:
        // int err;
        // int16_t adc_mv;
        printk("TEST\n");
        k_timer_status_sync(&adc_sampling_timer);
        k_timer_init(&adc_sampling_timer, NULL, NULL);
        k_timer_start(&adc_sampling_timer, K_MSEC(1000), K_MSEC(1000));
    I have also tried building and running this program on a nRF52832 DK, but I'm getting the same results.
  • Hm this seems very strange to me.
    Do you see it triggering four times in a row at each expiry, or do you see the triggers evenly spread out between each expiry?
    -Einar
  • From what I can observe, it's triggered 4 times in a row.
    To test this, I have changed the timer and work handlers to print out printk() messages, and this is the result I get (notice the timestamps):
    08:01:38:359 -> shell:~$ Test timer expiry
    08:01:40:340 -> Test work handler
    08:01:40:341 -> Test timer expiry
    08:01:40:343 -> Test work handler
    08:01:4Test timer expiry
    08:01:40:347 -> Test work handler
    08:01:40:351 -> Test timer expiry
    08:01:40:355 -> Test work handler
    08:01:40:359 -> shell:~$ Test timer expiry
    08:01:42:340 -> Test work handler
    08:01:42:341 -> Test timer expiry
    08:01:42:343 -> Test work handler
    08:01:42:347 -> Test work handler
    08:01:42:351 -> Test timer expiry
    08:01:42:355 -> Test work handler
    08:01:42:359 -> shell:~$ Test timer expiry
    08:01:44:340 -> Test work handler
    08:01:44:341 -> Test timer expiry
    08:01:44:343 -> Test work handler
    08:01:44:347 -> Test work handler
    08:01:44:351 -> Test timer expiry
    08:01:44:355 -> Test work handler
    08:01:44:359 -> shell:~$ Test timer expiry
    08:01:46:340 -> Test work handler
    08:01:46:341 -> Test timer expiry
    08:01:46:343 -> Test work handler
    08:01:46:347 -> Test work handler
    08:01:46:351 -> Test timer expiry
    08:01:46:355 -> Test work handler
    08:01:46:359 -> shell:~$ Test timer expiry
    08:01:48:340 -> Test work handler
    08:01:48:341 -> Test timer expiry
    08:01:48:343 -> Test work handler
    08:01:48:347 -> Test work handler
    08:01:48:351 -> Test timer expiry
    08:01:48:355 -> Test work handler
    08:01:48:359 -> shell:~$ Test timer expiry
    08:01:50:340 -> Test work handler
    08:01:50:341 -> Test timer expiry
    08:01:50:343 -> Test work handler
    08:01:5Test timer expiry
    08:01:50:347 -> Test work handler
    08:01:50:351 -> Test timer expiry
    08:01:50:355 -> Test work handler
    08:01:50:359 -> shell:~$ Test timer expiry
    08:01:52:340 -> Test work handler
    08:01:52:341 -> Test timer expiry
    08:01:52:343 -> Test work handler
    08:01:52:347 -> Test work handler
    08:01:52:351 -> Test timer expiry
    08:01:52:355 -> Test work handler
    08:01:52:359 -> shell:~$
    Also, just now, I have noticed that CONFIG_LOG_MODE_DEFERRED=n that I have set in the proj.conf is not applied to the build .config.
    So I added CONFIG_LOG_MODE_IMMEDIATE=y to the proj.conf as well, and it did reduce the number of "triggers" to 2, so instead I'm getting: (I have commented the timer handler printk())
    11:19:52:870 -> shell:~$ Test work handler
    11:19:5Test work handler
    11:19:53:869 -> shell:~$ Test work handler
    11:19:54:870 -> shell:~$ Test work handler
    11:19:55:870 -> shell:~$ Test work handler
    11:19:56:870 -> shell:~$ Test work handler
    11:19:57:869 -> shell:~$ Test work handler
    11:19:58:869 -> shell:~$ Test work handler
    11:19:59:870 -> shell:~$ Test work handler
    11:20:0Test work handler
    11:20:00:870 -> shell:~$ Test work handler
    11:20:01:870 -> shell:~$ Test work handler
    11:20:02:870 -> shell:~$ Test work handler
    11:20:03:869 -> shell:~$ Test work handler
    Could this just be a logger issue? The timer interval is 1000ms, by the way.
