Dear Support Team,
I recently started evaluating a nRF52833 DK board with the nRF Connect SDK 2.3.0.
I noticed a very strange behaviour while developing an ADXL accelerometer driver with interrupt handling. This is the setup and the symptoms:
Interrupt is configured on pin 4:
// dts file IRQ pin
custom_gpios {
compatible = "gpio-keys";
acc_irq_pin1: acc_irq_pin_1 {
gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
label = "ACC IRQ pin";
// handler
void ADXL_IRQhandler(const struct device *dev, struct gpio_callback *cb, uint32_t pins)
if(gpio_pin_get_dt(&sIRQ_pin) == 0)
printk("Inactivity interrupt\n");
printk("Activity interrupt\n");
//IRQ setup
int32_t ADXL_initIRQ(void)
if (!device_is_ready(sIRQ_pin.port))
printk("Error: gpio device %s is not ready\n", sIRQ_pin.port->name);
return -1;
if (gpio_pin_configure_dt(&sIRQ_pin, GPIO_INPUT) != 0)
printk("Error: failed to configure %s pin %d\n", sIRQ_pin.port->name, sIRQ_pin.pin);
return -2;
if (gpio_pin_interrupt_configure_dt(&sIRQ_pin, GPIO_INT_EDGE_BOTH) != 0)
printk("Error: failed to configure interrupt on %s pin %d\n", sIRQ_pin.port->name, sIRQ_pin.pin);
return -3;
gpio_init_callback(&sIRQ_callback, ADXL_IRQhandler, BIT(sIRQ_pin.pin));
if (gpio_add_callback(sIRQ_pin.port, &sIRQ_callback)!= 0)
printk("Error: failed to add ACC IRQ callback\n");
return -4;
return 0;
After freshly flashing the MCU everything works fine, interrupt handling is great, no problems. Until I power down the kit... when it is repowered again interrupt handling stops working completely and even resetting the board won't help. But when re-flashing the exact same firmware it starts working again!
Do you have any guess why this is happening?
Thank you and all the best,
Viktor
