Hello, I want to get GPS location information with nRF52840, I use UART protocol at 9600 baud rate, but I cannot read the data regularly, how should I do?
yes i am using existing driver made necessary adjustments according to datasheet
Can you share a trace from a logic analyzer that shows the data on RX and TX when you request GPS location?
Berkay Dudu said:yes i am using existing driver made necessary adjustments according to datasheet
Can you show me this in your code?
regards
Jared
Hi
Sorry I havent logic analyzer device, therefor I will send the code
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
//#define ENABLE_LOOPBACK_TEST /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
/* Use flow control in loopback test. */
#define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
bsp_board_leds_on();
while (true)
// Do nothing.
/** @brief Function for testing UART loop back.
* @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
* @note @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
static void uart_loopback_test()
uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
uint8_t rx_data;
// Start sending one byte and see if you get the same
for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
uint32_t err_code;
while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
nrf_delay_ms(10);
err_code = app_uart_get(&rx_data);
if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
show_error();
return;
#else
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
NRF_UART_BAUDRATE_9600
#else
NRF_UARTE_BAUDRATE_9600
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
#ifndef ENABLE_LOOPBACK_TEST
printf("\r\nUART example started.\r\n");
while (true)
//char a[100];
uint8_t cr;
//uint8_t i;
//double cr;
//while (app_uart_get(&cr) != NRF_SUCCESS);
//while (app_uart_put(cr) != NRF_SUCCESS);
//if (cr == 't' || cr == 'Q')
// printf(" \r\nExit!\r\n");
// while (true)
// bsp_board_leds_on();
if(app_uart_get(&cr) != NRF_SUCCESS)
printf(cr,'\r\n');
nrf_delay_ms(500);
//else
// //printf("i degeri : %d", i);
// printf(cr);
// nrf_delay_ms(500);
#else
// This part of the example is just for testing the loopback .
while (true)
uart_loopback_test();
Where in the code that you've shared do you use the driver to configure the GPS?
regards
Jared
When the code added the line "flow_control = APP_UART_FLOW_CONTROL_DISABLED" and changed the location of the pins on the board, the data came in this way, but upload different codes and the same data is coming. How can I control the future and how can I filter it?
