HardFault on sd_flash_write
I have a problem with the sd_flash_write function. It HardFaults on me and I can't seem to find out why. The Addresses are 4 byte aligned...
The function is called with: err = sd_flash_write(0x34800, 0x20002a50, 1);
If anyone know assembler, maybe this helps?:
133       	else if(
0002105a:   subs r3, #1
0002105c:   cmp r3, #1
0002105e:   bls.n 0x21062 <Testing::TerminalCommandHandler(std::string, std::vector<std::string, std::allocator<std::string> >)+230>
00021060:   b.n 0x21256 <Testing::TerminalCommandHandler(std::string, std::vector<std::string, std::allocator<std::string> >)+730>
139       		err = sd_flash_write(params->dataDestination, params->dataSource, params->dataLength / 4);
>>> 00021062:   ldrh r2, [r4, #16]
00021064:   ldr r1, [r4, #8]
00021066:   lsrs r2, r2, #2
00021068:   ldr r0, [r4, #12]
This happens with the "optimize size" (-Os) option in GCC, if I use -o1, everything works, but that could be due to different alignment and some luck, though the destination and source address remain the same.
Here's the version with -O1: 133
      	else if(
0002490c:   subs r3, #1
0002490e:   cmp r3, #1
00024910:   bhi.n 0x2496c <Testing::TerminalCommandHandler(std::string, std::vector<std::string, std::allocator<std::string> >)+384>
>>> 00024912:   ldrh r2, [r4, #16]
00024914:   lsrs r2, r2, #2
00024916:   ldr r0, [r4, #12]
00024918:   ldr r1, [r4, #8]
Thanks, Marius
