Dear Nordic Developers!
When I call the sd_power_system_off() function to put the MCU to system OFF, after that I can still see the advertiser device in MasterControlPanel. Is it a normal behaviour? The case is the same, when I call sd_ble_gap_adv_stop() before sd_power_system_off().
How much could be the maximum current consumption when advertising is on at system OFF state?
Thank you for the help in advance!
Ps.: I use nRF51422-QFAA-E0 with S130, SDK 8.1.0 with BLE_ADV_MODE_FAST adv. config.
The image below is captured, when the device is already in system OFF.
Update1:
static void Enter_SleepMode_f(void) { uint32_t err_code;
nrf_gpio_cfg_sense_input(GPIO_BUTTON1, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH); // Wake up button
// Turn off all LEDs
nrf_gpio_pin_set(GPIO_LED1);
nrf_gpio_pin_set(GPIO_LED2);
nrf_gpio_pin_set(GPIO_LED3);
nrf_gpio_pin_set(GPIO_LED4);
nrf_gpio_pin_clear(GPIO_ENCAL); // Disables the 3.3V feed of MCP6N11 and TLC272CD amplifiers
// Disable LPCOMP and its interrupts
NRF_LPCOMP->ENABLE = LPCOMP_ENABLE_ENABLE_Disabled;
sd_nvic_DisableIRQ(LPCOMP_IRQn);
// Stops all application timers
app_timer_stop_all();
