I'm using an nrf9160 to count the number of falling edges on a GPIO pin using a timer without any processor intervention, aside from capturing the number after some interval elsewhere. It sounds like DPPI is my best bet, but I can't seem to find any information about my specific use case outside of the Nordic documentation.
My method of capturing the timer value doesn't seem right, but I haven't found any resources telling me so. I'm experimenting with S and NS configurations since there's a line that reads "non-secure peripherals can only subscribe to non-secure channels". I'm seeing quite a lot of potential areas where my logic may be broken, so I was hoping to get some direction as to why my code doesn't work properly.
#include "pulseDriver.h" #include <zephyr/kernel.h> #include <nrfx_dppi.h> #define INP_PIN 8 void pulseDriver_init(void) { // Configure IO pin uint32_t configInt = 0; configInt |= 1; // event mode configInt |= INP_PIN << 8; // Specify pin number configInt |= 2 << 16; // Trigger when going from hi to lo NRF_GPIOTE1_NS->CONFIG[0] = configInt; // Assign config NRF_GPIOTE1_NS->PUBLISH_IN[0] = 1; // enable publishing // Configure timer NRF_TIMER1->MODE = 1; // 0: timer mode. 1: Counter mode. 2: low power counter mode NRF_TIMER1->SUBSCRIBE_COUNT = (1 << 31) | 0; // Enable subscription for count task, subscribe to channel 0 // Timer's default size is 16, which seems sufficient // Enable the channel that the above are tied to NRF_DPPIC->CHENSET = (1 << 1) | (1 << 0); NRF_TIMER1->TASKS_START = 1; // Enable the timer. } // Gets total number of pulses since last record uint32_t pulseDriver_getCount() { uint32_t returnVar; // Record timer to return variable NRF_TIMER1->TASKS_CAPTURE[0] = 1; // Capture timer value into CC returnVar = NRF_TIMER1->CC[0]; return returnVar; }
Thanks in advance
