s130 proximity
Lately I tried the example proximity with S130. But I found it did not work as if it is with S110. Particularly, I found the irk_match flag in the following code segment from device_manager_peripheral.c is always set even it is not at whitelist advertising mode.
    case BLE_GAP_EVT_CONNECTED:
        //Allocate connection instance for a new connection.
        err_code = connection_instance_allocate(&index);
        //Connection instance is successfully allocated.
        if (err_code == NRF_SUCCESS)
            //Application notification related information.
            notify_app           = true;
            event.event_id       = DM_EVT_CONNECTION;
            handle.connection_id = index;
            m_connection_table[index].conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            m_connection_table[index].state       = STATE_CONNECTED;
            m_connection_table[index].peer_addr   =
                p_ble_evt->evt.gap_evt.params.connected.peer_addr;
            if (p_ble_evt->evt.gap_evt.params.connected.irk_match == 1)
                if (m_irk_index_table[p_ble_evt->evt.gap_evt.params.connected.irk_match_idx] != DM_INVALID_ID)
                    device_index = m_irk_index_table[p_ble_evt->evt.gap_evt.params.connected.irk_match_idx];
                    err_code = NRF_SUCCESS;
                //Use the device address to check if the device exists in the bonded device list.
                err_code = device_instance_find(&p_ble_evt->evt.gap_evt.params.connected.peer_addr,
                                                &device_index, EDIV_INIT_VAL);
                m_connection_table[index].bonded_dev_id = device_index;
                m_connection_table[index].state        |= STATE_BONDED;
                handle.device_id                        = device_index;
                bond_data_load(&handle);
I am using S130 hex in the nRF5_SDK_9.0.0. Wish I will have your hint of why the difference.
