Getting started with gpio overlay
Hi
I am really struggling to get started with overlay files. I have read through a lot of documentation, watched a few hours of YouTube tutorials, and yet I can’t even get going with one gpio.
I have an existing project for the nRF5340_DK, based I think on Nordic’s BLE UART Peripheral example.
I had to change the pins used for the i2c bus, so I managed to hack an overlay fiel for that, which works – but probably isn’t correct.
So now I want to try using one of the GPIO, as an output.
The examples I found were here and here.
I couldn't get either to build.
Any help / guidance / pointers would be appreciated, thank you.
DETAILS
I decided to pick gpio0.25, and then gpio0.26, since they seem to be free.
Here is my overlay file – you will see both attempts at the end of the file – one commented out:
 * Copyright (c) 2022 Nordic Semiconductor ASA
	chosen {
		nordic,nus-uart = &uart0;
&pinctrl {
	i2c2_default: i2c2_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 0, 6)>, <NRF_PSEL(TWIM_SDA, 0, 7)>;
	i2c2_sleep: i2c2_sleep {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 7)>,
				<NRF_PSEL(TWIM_SCL, 0, 6)>;
			low-power-enable;
&i2c2 {
	status = "okay";
	pinctrl-0 = <&i2c2_default>;
	pinctrl-1 = <&i2c2_default>;
&uart0_default {
	group2 {
		psels = <NRF_PSEL(UART_RX, 0, 22)>, <NRF_PSEL(UART_CTS, 0, 21)>;
&uart0_default {
	group1 {
		psels = <NRF_PSEL(UART_RTS, 0, 19)>;
// !gpio! - start
// From example here: https://devzone.nordicsemi.com/f/nordic-q-a/94963/need-simple-devicetree-overlay-example-for-gpio
	custom_gpios {
	   compatible = "gpio-keys";
	   cusgpio0: cusgpio_0 {
		  gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
		  label = "My custom GPIO";
	aliases {
	mycusgpio = &cusgpio0;
// From example here: https://devzone.nordicsemi.com/f/nordic-q-a/72618/extra-gpios-in-board-overlay-for-nrf9160dk
    gpiocustom {
        gpiocus0: gpiocus_0 {
            gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 25";
        gpiocus1: gpiocus_1 {
            gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 26";
    aliases {
        gpiocus0 = &gpiocus0;
        gpiocus1 = &gpiocus1;
// !gpio! – end
And in main.c, again – two attempts, one commented out:
// !gpio! - start
//#define GPIO025_NODE  DT_ALIAS(mycusgpio)
//#define GPIO025           DT_GPIO_LABEL(GPIO025_NODE, gpios)
#define GPIO025_NODE    DT_ALIAS(gpiocus0)
// !gpio! - end
And in main():
    const struct device *dev_gpio0;                 // !gpio!
    dev_gpio0 = device_get_binding(GPIO025);        // !gpio!
Here are the warnings and errors I get for the first build (for gpio0.25 only – which is the attempt commented out above):
src\main.c:213:13: warning: Macro is deprecated
  213 |  dev_gpio0 = device_get_binding(GPIO025);
 build\zephyr\include\generated\devicetree_unfixed.h:1749:58: error: 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_label' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_reg'?
 1749 | #define DT_N_S_custom_gpios_S_cusgpio_0_P_gpios_IDX_0_PH DT_N_S_soc_S_peripheral_40000000_S_gpio_842500
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in definition of macro 'DT_CAT'
 3068 | #define DT_CAT(a1, a2) a1 ## a2
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:106:2: note: in expansion of macro 'DT_PROP'
  106 |  DT_PROP(DT_GPIO_CTLR_BY_IDX(node_id, gpio_pha, idx), label) __DEPRECATED_MACRO
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3076:41: note: in expansion of macro 'DT_N_S_custom_gpios_S_cusgpio_0_P_gpios_IDX_0_PH'
 3076 | #define DT_CAT6(a1, a2, a3, a4, a5, a6) a1 ## a2 ## a3 ## a4 ## a5 ## a6
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:1247:2: note: in expansion of macro 'DT_CAT6'
 1247 |  DT_CAT6(node_id, _P_, prop, _IDX_, idx, _PH)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:54:2: note: in expansion of macro 'DT_PHANDLE_BY_IDX'
   54 |  DT_PHANDLE_BY_IDX(node_id, gpio_pha, idx)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:106:10: note: in expansion of macro 'DT_GPIO_CTLR_BY_IDX'
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:120:2: note: in expansion of macro 'DT_GPIO_LABEL_BY_IDX'
  120 |  DT_GPIO_LABEL_BY_IDX(node_id, gpio_pha, 0) __DEPRECATED_MACRO
 src\main.c:64:19: note: in expansion of macro 'DT_GPIO_LABEL'
   64 | #define GPIO025   DT_GPIO_LABEL(GPIO025_NODE, gpios)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in expansion of macro 'DT_N_ALIAS_mycusgpio'
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:213:25: note: in expansion of macro 'DT_CAT'
  213 | #define DT_ALIAS(alias) DT_CAT(DT_N_ALIAS_, alias)
 src\main.c:63:22: note: in expansion of macro 'DT_ALIAS'
   63 | #define GPIO025_NODE DT_ALIAS(mycusgpio)
 src\main.c:64:33: note: in expansion of macro 'GPIO025_NODE'
 src\main.c:213:33: note: in expansion of macro 'GPIO025'
 build\zephyr\include\generated\devicetree_unfixed.h:1749:58: note: each undeclared identifier is reported only once for each function it appears in
[27/221] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[29/219] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
FATAL ERROR: command exited with status 1
And the error and warning for my second attempt:
../src/main.c: In function 'main':
src\main.c:215:13: warning: Macro is deprecated
  215 |  dev_gpio0 = device_get_binding(GPIO025);  // !gpio!
build\zephyr\include\generated\devicetree_unfixed.h:1752:56: error: 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_label' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_reg'?
 1752 | #define DT_N_S_gpiocustom_S_gpiocus_0_P_gpios_IDX_0_PH DT_N_S_soc_S_peripheral_40000000_S_gpio_842500
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3076:41: note: in expansion of macro 'DT_N_S_gpiocustom_S_gpiocus_0_P_gpios_IDX_0_PH'
src\main.c:66:19: note: in expansion of macro 'DT_GPIO_LABEL'
   66 | #define GPIO025   DT_GPIO_LABEL(GPIO025_NODE, gpios)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in expansion of macro 'DT_N_ALIAS_gpiocus0'
src\main.c:65:22: note: in expansion of macro 'DT_ALIAS'
   65 | #define GPIO025_NODE DT_ALIAS(gpiocus0)
src\main.c:66:33: note: in expansion of macro 'GPIO025_NODE'
src\main.c:215:33: note: in expansion of macro 'GPIO025'
build\zephyr\include\generated\devicetree_unfixed.h:1752:56: note: each undeclared identifier is reported only once for each function it appears in
[27/222] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[29/220] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[30/220] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/garrett/ncs/v2.1.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
[31/220] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
By the way, I don’t know where this came from, in the overlay file – I suspect is was from when I was playing with the Device Tree GUI:
&uart0_default {
	group2 {
&uart0_default {
	group1 {
  • Hi
    I feel like I am getting closer to a solution, but…
    So here’s the code from my overlay:
        gpiocustom {
                label = "Custom gpio 28";
                label = "Custom gpio 29";
        aliases {
    My defines:
    #define CUS_PIN0_NODE	DT_NODELABEL(gpiocus0)
    #define CUS_PIN0		DT_GPIO_PIN(CUS_PIN0_NODE, gpios)
    And the code in main()
    	dev_gpio0 = DEVICE_DT_GET(DT_NODELABEL(gpiocus0));
    	if (!device_is_ready(dev_gpio0)) {
    		printk("main: gpio not ready\n");
    	gpio_pin_configure(dev_gpio0, CUS_PIN0,  GPIO_OUTPUT);
    	gpio_pin_set(dev_gpio0, CUS_PIN0, 0);
    Resulting in this error:
    C:\dev\myapp\src\main.c:296: undefined reference to `__device_dts_ord_19'
    I am sorry, but we are short staffed this week due to Public Holidays in Norway. We will be back on Monday 22nd and hope to be able to answer all incoming requests within a couple of days, depending on the backlog. I am sorry for the inconvenience.
    Priyanka
  • Hi Garrett,
    Were you able to get it working? Have you taken a look into the overlay guide that we have? Also, from the NCS v2.0.0 onwards, we have the pinctrl introduced, about which you can read more here.
    -Priyanka
  • Hi Priyanka,
    no, I have not been able to get it working so far.
    I don't understand why all the sample code in the "read more here" link is using the uart0 pins.
    Is there no example to use just an ordinary pin - one that is not already assigned to a uart?
    I am sure this will all make sense, once it makes sense, but for now it is impossible for me to understand.
    For example, reading through the nRF5340DK spec, it seems to indicate that the following gpio, available at various connectors, are unassigned:
    P2: P0.04..07, 25, 26
    P3: P1.00, 01, 04..09
    P4: P1.10..15, 27
    P5: P1.13..15
    P6: P0.02, 03, 07, 10
    P24: P0.11, 12, 28..31
    So how would I define/use, e.g. P0.04 as a digital output, and P0.05 as a digital input?
    G
  • Hi Garrett,
    What you wrote seems to be correct, but it would be great to know what the line 296 is in your main.c ?
    Maybe there is some referencing problem.
    I will also try to reproduce the error, in the meantime.
    -Priyanka
