Getting started with gpio overlay
Hi
I am really struggling to get started with overlay files. I have read through a lot of documentation, watched a few hours of YouTube tutorials, and yet I can’t even get going with one gpio.
I have an existing project for the nRF5340_DK, based I think on Nordic’s BLE UART Peripheral example.
I had to change the pins used for the i2c bus, so I managed to hack an overlay fiel for that, which works – but probably isn’t correct.
So now I want to try using one of the GPIO, as an output.
The examples I found were here and here.
I couldn't get either to build.
Any help / guidance / pointers would be appreciated, thank you.
DETAILS
I decided to pick gpio0.25, and then gpio0.26, since they seem to be free.
Here is my overlay file – you will see both attempts at the end of the file – one commented out:
 * Copyright (c) 2022 Nordic Semiconductor ASA
	chosen {
		nordic,nus-uart = &uart0;
&pinctrl {
	i2c2_default: i2c2_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 0, 6)>, <NRF_PSEL(TWIM_SDA, 0, 7)>;
	i2c2_sleep: i2c2_sleep {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 7)>,
				<NRF_PSEL(TWIM_SCL, 0, 6)>;
			low-power-enable;
&i2c2 {
	status = "okay";
	pinctrl-0 = <&i2c2_default>;
	pinctrl-1 = <&i2c2_default>;
&uart0_default {
	group2 {
		psels = <NRF_PSEL(UART_RX, 0, 22)>, <NRF_PSEL(UART_CTS, 0, 21)>;
&uart0_default {
	group1 {
		psels = <NRF_PSEL(UART_RTS, 0, 19)>;
// !gpio! - start
// From example here: https://devzone.nordicsemi.com/f/nordic-q-a/94963/need-simple-devicetree-overlay-example-for-gpio
	custom_gpios {
	   compatible = "gpio-keys";
	   cusgpio0: cusgpio_0 {
		  gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
		  label = "My custom GPIO";
	aliases {
	mycusgpio = &cusgpio0;
// From example here: https://devzone.nordicsemi.com/f/nordic-q-a/72618/extra-gpios-in-board-overlay-for-nrf9160dk
    gpiocustom {
        gpiocus0: gpiocus_0 {
            gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 25";
        gpiocus1: gpiocus_1 {
            gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
            label = "Custom gpio 26";
    aliases {
        gpiocus0 = &gpiocus0;
        gpiocus1 = &gpiocus1;
// !gpio! – end
And in main.c, again – two attempts, one commented out:
// !gpio! - start
//#define GPIO025_NODE  DT_ALIAS(mycusgpio)
//#define GPIO025           DT_GPIO_LABEL(GPIO025_NODE, gpios)
#define GPIO025_NODE    DT_ALIAS(gpiocus0)
// !gpio! - end
And in main():
    const struct device *dev_gpio0;                 // !gpio!
    dev_gpio0 = device_get_binding(GPIO025);        // !gpio!
Here are the warnings and errors I get for the first build (for gpio0.25 only – which is the attempt commented out above):
src\main.c:213:13: warning: Macro is deprecated
  213 |  dev_gpio0 = device_get_binding(GPIO025);
 build\zephyr\include\generated\devicetree_unfixed.h:1749:58: error: 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_label' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_reg'?
 1749 | #define DT_N_S_custom_gpios_S_cusgpio_0_P_gpios_IDX_0_PH DT_N_S_soc_S_peripheral_40000000_S_gpio_842500
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in definition of macro 'DT_CAT'
 3068 | #define DT_CAT(a1, a2) a1 ## a2
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:106:2: note: in expansion of macro 'DT_PROP'
  106 |  DT_PROP(DT_GPIO_CTLR_BY_IDX(node_id, gpio_pha, idx), label) __DEPRECATED_MACRO
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3076:41: note: in expansion of macro 'DT_N_S_custom_gpios_S_cusgpio_0_P_gpios_IDX_0_PH'
 3076 | #define DT_CAT6(a1, a2, a3, a4, a5, a6) a1 ## a2 ## a3 ## a4 ## a5 ## a6
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:1247:2: note: in expansion of macro 'DT_CAT6'
 1247 |  DT_CAT6(node_id, _P_, prop, _IDX_, idx, _PH)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:54:2: note: in expansion of macro 'DT_PHANDLE_BY_IDX'
   54 |  DT_PHANDLE_BY_IDX(node_id, gpio_pha, idx)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:106:10: note: in expansion of macro 'DT_GPIO_CTLR_BY_IDX'
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree\gpio.h:120:2: note: in expansion of macro 'DT_GPIO_LABEL_BY_IDX'
  120 |  DT_GPIO_LABEL_BY_IDX(node_id, gpio_pha, 0) __DEPRECATED_MACRO
 src\main.c:64:19: note: in expansion of macro 'DT_GPIO_LABEL'
   64 | #define GPIO025   DT_GPIO_LABEL(GPIO025_NODE, gpios)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in expansion of macro 'DT_N_ALIAS_mycusgpio'
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:213:25: note: in expansion of macro 'DT_CAT'
  213 | #define DT_ALIAS(alias) DT_CAT(DT_N_ALIAS_, alias)
 src\main.c:63:22: note: in expansion of macro 'DT_ALIAS'
   63 | #define GPIO025_NODE DT_ALIAS(mycusgpio)
 src\main.c:64:33: note: in expansion of macro 'GPIO025_NODE'
 src\main.c:213:33: note: in expansion of macro 'GPIO025'
 build\zephyr\include\generated\devicetree_unfixed.h:1749:58: note: each undeclared identifier is reported only once for each function it appears in
[27/221] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[29/219] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
FATAL ERROR: command exited with status 1
And the error and warning for my second attempt:
../src/main.c: In function 'main':
src\main.c:215:13: warning: Macro is deprecated
  215 |  dev_gpio0 = device_get_binding(GPIO025);  // !gpio!
build\zephyr\include\generated\devicetree_unfixed.h:1752:56: error: 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_label' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_gpio_842500_P_reg'?
 1752 | #define DT_N_S_gpiocustom_S_gpiocus_0_P_gpios_IDX_0_PH DT_N_S_soc_S_peripheral_40000000_S_gpio_842500
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3076:41: note: in expansion of macro 'DT_N_S_gpiocustom_S_gpiocus_0_P_gpios_IDX_0_PH'
src\main.c:66:19: note: in expansion of macro 'DT_GPIO_LABEL'
   66 | #define GPIO025   DT_GPIO_LABEL(GPIO025_NODE, gpios)
C:\Users\me\ncs\v2.1.0\zephyr\include\zephyr\devicetree.h:3068:24: note: in expansion of macro 'DT_N_ALIAS_gpiocus0'
src\main.c:65:22: note: in expansion of macro 'DT_ALIAS'
   65 | #define GPIO025_NODE DT_ALIAS(gpiocus0)
src\main.c:66:33: note: in expansion of macro 'GPIO025_NODE'
src\main.c:215:33: note: in expansion of macro 'GPIO025'
build\zephyr\include\generated\devicetree_unfixed.h:1752:56: note: each undeclared identifier is reported only once for each function it appears in
[27/222] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[29/220] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[30/220] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/garrett/ncs/v2.1.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
[31/220] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
By the way, I don’t know where this came from, in the overlay file – I suspect is was from when I was playing with the Device Tree GUI:
&uart0_default {
	group2 {
&uart0_default {
	group1 {
