[nRF24L01+] How to use Auto Acknowledge
Hello all,
1. I have a transmitter (Arduino Pro Mini 5V) connected to a nRF24L01+. I use the following code to set up the radio.
    radio.begin();
    radio.setChannel(125);
    radio.setPALevel(RF24_PA_LOW);
    radio.setDataRate(RF24_1MBPS);
    radio.setAddressWidth(5);
    radio.setAutoAck(true);
    radio.setRetries(5, 3);
    radio.setPayloadSize(sizeof(radio_data));
    radio.openWritingPipe(address);
    radio.stopListening();
2. I have a receiver (ESP32) coonecter to a nRF24L01+. I use the following code to set up the radio.
    radio.begin();
    radio.openReadingPipe(0, address);
    radio.startListening();
3. When I want to transmit data, I call the function write.
The return of the call to the function write is always false, meaning that auto acknowledgement goes wrong.
Have you any idea of what I did wrong ?
Thanks for your help.
  • Hi Pascal
    Do you have the capability to send raw SPI commands to the module, bypassing the L01+ library?
    It should be possible to enable the module and send packets with ACK using only a handful of SPI commands. If you are able to bypass the library and control the SPI and GPIO directly I can suggest a short test sequence that can verify that the hardware is OK. Then we have to figure out what is different when using the library, and (ideally) how to make the library work correctly.
    Best regards
    Torbjørn
    I agree with your proposal.
    Let me know the data you want me to send/receive on the SPI as a test sequence and what result to provide to you.
    Pascal
  • Hi Pascal
    Probably the most stripped down sequence for establishing communication goes something like this:
    PTX
    Set CONFIG register to 0x0E  (PRWUP = 1, CRC 16 bit, PRIM_RX 0)
    Write 0x20, 0x0E
    Add a 2ms delay
    Now the transmitter should be ready. To send a packet, start by uploading a packet
    Write 0xA0, 0x01, 0x02, 0x03, 0x04 (only the first byte is important, the remaining bytes can be whatever you like)
    Pulse the CE line for 100us in order to start the transmission
    In a loop, read the STATUS register and wait for bit 4 or 5 to be set
    Write 0x07, 0x00 and check the return value. If nothing happened the return value should be 0x0E. Once you get an interrupt it should be 0x2E (TX successful) or 0x1E (TX failed).
    To prepare for another packet, clear the IRQ bits by writing 0x70 to the STATUS register:
    Write 0x27, 0x70
    PRX
    Set CONFIG register to 0x0F  (PRWUP = 1, CRC 16 bit, PRIM_RX 1)
    Write 0x20, 0x0F
    Add a 2ms delay
    Configure the payload length on pipe 0 to 4 bytes (or whichever number of bytes you plan to send from the PTX side)
    Write 0x31, 0x04
    Set the CE line high permanently to enable the receiver
    In a loop, read the STATUS register and wait for bit  6 to be set
    Write 0x07, 0x00 and check the return value. If nothing happened the return value should be 0x0E. Once you receive a packet it should be 0x40.
    Write 0x27, 0x70
    Would you be able to follow this procedure and see if the status register changes on either side, indicating a successful transaction?
    There is a bit more work if you want ot read out the payload on the RX side, but the main point at the moment is to verify that your hardware works properly.
    Best regards
    Torbjørn
    I wrote the code based on the above sequence for the PRX and PTX. I only add the reading of the received frame in the PRX sequence.
    It works fine.
    The PTX sends the frame every 500ms and then the PRX receives it perfectly at the same rate.
    Do you want to get SPI captures, from PRX, from PTX?
    What are the next steps?
    Pascal
    Today, I got some errors during the auto ACK.
    I share with you the capture file with CE from the start : https://drive.google.com/file/d/1qYhx9URnSculNCKtLedLqEY8i-KrhAHp/view?usp=sharing
    Pascal
