[nRF24L01+] How to use Auto Acknowledge
Hello all,
1. I have a transmitter (Arduino Pro Mini 5V) connected to a nRF24L01+. I use the following code to set up the radio.
    radio.begin();
    radio.setChannel(125);
    radio.setPALevel(RF24_PA_LOW);
    radio.setDataRate(RF24_1MBPS);
    radio.setAddressWidth(5);
    radio.setAutoAck(true);
    radio.setRetries(5, 3);
    radio.setPayloadSize(sizeof(radio_data));
    radio.openWritingPipe(address);
    radio.stopListening();
2. I have a receiver (ESP32) coonecter to a nRF24L01+. I use the following code to set up the radio.
    radio.begin();
    radio.openReadingPipe(0, address);
    radio.startListening();
3. When I want to transmit data, I call the function write.
The return of the call to the function write is always false, meaning that auto acknowledgement goes wrong.
Have you any idea of what I did wrong ?
Thanks for your help.
    I share with you a capture file with CEs of SPI for both PTX and PRX from the start : https://drive.google.com/file/d/1mi6D-tu33AO6Ovo6XV2cg7CNmShpeRCI/view?usp=sharing
    At 16s141ms800, there is a fail of the auto ACK (last status equals to 0x1E).
    Just before, at 16s141ms100, this is the TX data packet corresponding to the fail auto ACK. The last byte of this data is 0x19 and can be used to search in the PRX capture if the corresponding data has been received.
    The last byte of the TX data packet is increased by 1 at each transfer, so that this last byte is different from one transfer to the previous/next one.
    If you scrolls down to look at the RX SPI capture, you can see that the data packet with last byte equals to 0x19 is read from the nRF24L01 just before 16s141ms800.
    Additional question: do you know why at 4s612ms440 there is a status set to 0x0C on the RX MISO, which does not seem to correspond to something correct?
    Pascal
  • Hi Pascal,
    Torbjørn is on vacation and will be away until beginning of August.
    We will have to wait for him to be back to answer your questions.
  • Hi Pascal
    I am now back from vacation and I can take a look at the traces. Could you just let me know if there has been any updates or discoveries from you in the mean time, or if the question is still the same as when you posted your question?
    Best regards
    Torbjørn
    My concern is still valid.
    Have a look to my last 3 messages above.
    The last message above includes a link to a capture of both SPIs of PTX and PRX.
    Pascal
  • Hi Pascal
    If I understand your question correctly you are wondering why the PTX is getting the MAX_RT (TX failed) interrupt even when the packet is received by the PRX?
    This can happen whenever the original packet from the PTX to the PRX is received by the PRX, but the ACK packet back to the PTX is lost. In this case the PRX will report an RX interrupt and the PTX will report the MAX_RT interrupt. The normal way to handle this is to retransmit the packet from the PTX, then the PRX will read it as a retransmission and simply ACK the packet again without adding it to the RX FIFO (or raising the RX interrupt again).
    Figure 24 on page 48 of the datasheet shows a variant of this scenario, where neither of the ACK packets sent by the PRX are received by the PTX, and the PTX will report the MAX_RT interrupt even if the packet was received by the PRX.
    Increasing the retransmit counter (ARC) in the SETUP_RETR register will reduce the chance of this happening, since the PTX will attempt more times before issuing the MAX_RT interrupt.
    Looking at your trace it doesn't seem like this register is set to a higher value.
    Interesting, I have never seen this behavior before. It seems the STATUS register is being read just as a packet is received, and an intermediary value between 0x0E and 0x40 is returned. This might be a side effect of reading the STATUS register at such a high rate (when using the IRQ line you typically only read the STATUS register once IRQ goes low).
    Either way it seems the library is using the second byte on MISO to determine status, so this shouldn't have a negative effect on the application.
    Best regards
    Torbjørn
