using persistent data storage, NRF Connect.
I am trying to save some data in flash.
it works, but it corrupts the Bluetooth thread .
If  I call my_settings_init(), then bt_enable(NULL) never returns.
in prj.conf I added:
# config using settings store and load:
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# in file my.overlay the storage allocated is 8 pages = 32K (8 x 0x1000)
CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
the my.overlay is as so:
&flash0 {
   partitions {
       #address-cells = <1>;
       #size-cells = <1>;
       storage_partition: partition@78000 {
           label = "storage";
           reg = <0x00078000 0x00008000>;  // Allocate 32K for settings storage
added in Cmakelist.txt:
set(DTC_OVERLAY_FILE "my.overlay")
 BT working is no setting system is used, setting working but currups BT.
What is wrong?
Thanks
void read_settings(void)
	settings_load();
int my_settings_init(void)
	int err = settings_subsys_init();
	if (err) {
		LOG_INF("Can't init settings subsys (%d)\n", err);
		return err;
	err = settings_register(&my_conf);
	if (err) {
		LOG_INF("Can't register my settings handler (%d)\n", err);
		return err;
	/* Load settings from persistent storage */
	read_settings();
	return 0;
    Thanks for the project.
    I am sorry, but I have misinformed you earlier. When a pm_static.yml file is present, the build-system assumes to use PartitionManager, even for single-image builds. The problem is that the firmware requires an added kconfig.
    In your prj.conf, try to add:
    CONFIG_PM_SINGLE_IMAGE=y
    PS: You need to set aside a minimum of two flash pages for the settings subsys:
    settings_storage:
        address: 0x7E000
        size: 0x2000 # changed this
        region: flash_primary
    Håkon
  • I tried, but no joy yet.
    I added in prj.conf:
    and fixed:
    CONFIG_SETTINGS_NVS_SECTOR_COUNT=2
    in pm_static.yml:
    settings_storage:
        address: 0x7D000  # fixed to 7D000
    Configuration build is OK but still have that build error:
    Severity Description        Project  File                                            Line
    Error    Partition Manager failed, aborting.  Command: C:/ncs/toolchains/v2.3.0/opt/bin/python.exe;E:/ncs/v2.3.0/nrf/scripts/partition_manager.py;--input-files;E:/MyWork/FeedSens_NRF_Connect/fdSensV2/build/nrf52dk_nrf52832/Debug/zephyr/include/generated/pm.yml;E:/MyWork/FeedSens_NRF_Connect/fdSensV2/build/nrf52dk_nrf52832/Debug/modules/nrf/subsys/partition_manager/pm.yml.settings;--regions;sram_primary;flash_primary;--output-partitions;E:/MyWork/FeedSens_NRF_Connect/fdSensV2/build/nrf52dk_nrf52832/Debug/partitions.yml;--output-regions;E:/MyWork/FeedSens_NRF_Connect/fdSensV2/build/nrf52dk_nrf52832/Debug/regions.yml;--static-config;E:/MyWork/FeedSens_NRF_Connect/fdSensV2/pm_static.yml;--sram_primary-size;0x10000;--sram_primary-base-address;0x20000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--flash_primary-size;0x80000;--flash_primary-base-address;0x0;--flash_primary-placement-strategy;complex;--flash_primary-device;flash_controller;--flash_primary-default-driver-kconfig;CONFIG_SOC_FLASH_NRF fdSensV2 E:\ncs\v2.3.0\nrf\cmake\partition_manager.cmake 304
    https://devzone.nordicsemi.com/f/nordic-q-a/99956/using-persistent-data-storage-nrf-connect/427116#
    BTW did you try to build the project?
    Thanks
    Johanan
  • Your offset address is incorrect in the pm_static.yml, shall be:
    address: 0x7e000
    for a size of 0x2000.
    Håkon
  • Well, that was rather silly of me :-), I should know HEX numbers already.
    Now it builds OK, I will test the setting save/load later today.
    Thanks very much.
    Johanan
