using persistent data storage, NRF Connect.
I am trying to save some data in flash.
it works, but it corrupts the Bluetooth thread .
If  I call my_settings_init(), then bt_enable(NULL) never returns.
in prj.conf I added:
# config using settings store and load:
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# in file my.overlay the storage allocated is 8 pages = 32K (8 x 0x1000)
CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
the my.overlay is as so:
&flash0 {
   partitions {
       #address-cells = <1>;
       #size-cells = <1>;
       storage_partition: partition@78000 {
           label = "storage";
           reg = <0x00078000 0x00008000>;  // Allocate 32K for settings storage
added in Cmakelist.txt:
set(DTC_OVERLAY_FILE "my.overlay")
 BT working is no setting system is used, setting working but currups BT.
What is wrong?
Thanks
void read_settings(void)
	settings_load();
int my_settings_init(void)
	int err = settings_subsys_init();
	if (err) {
		LOG_INF("Can't init settings subsys (%d)\n", err);
		return err;
	err = settings_register(&my_conf);
	if (err) {
		LOG_INF("Can't register my settings handler (%d)\n", err);
		return err;
	/* Load settings from persistent storage */
	read_settings();
	return 0;
  • The following creates a hard error:
    static ssize_t write_char_fun(struct bt_conn *conn,
    	const struct bt_gatt_attr *attr,
    	const void *buf,
    	uint16_t len,
    	uint16_t offset,
    	uint8_t flags)
    	LOG_INF("Attribute write, handle: %u, conn: %p",
    		attr->handle,
    		(void *)conn);
    	// store in eeprom:
    	if (len == 1)
    		house_id = ((int8_t *)buf)[0];
    		save_settings(); // ,<<<--- This creates MPU FAULT, Data Access violation
    		LOG_INF("Write House: %d ",house_id);
    		return len;
    	LOG_INF("Write House fail len=: %d ", len);
    	return BT_GATT_ERR(BT_ATT_ERR_INVALID_ATTRIBUTE_LEN);
    However, if I call save_settings()  just at main() , before anything else, like bt_enable() , it works OK, and writes the setting in memory.
    What can be the reason?
    Thanks.
    Johanan
  • I resolved the save_settings issue by taking it to the main loop from the write cb function, using a queue.
    So now it works, but I would like to know why it does not work from inside the char write cb function.
    BR
    Johanan
    //------  in the char write cb:
    	// store in eeprom:
    	if (len == 1)
    		// save_settings();// ,<<<--- This creates MPU FAULT, Data Access violation
    		k_msgq_put(&setting_q, NULL, K_FOREVER); // just signal to save settings in main
    		return len;
    	// --- and in the main loop:
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    		if (k_msgq_get(&setting_q, NULL, K_NO_WAIT)== 0)
    			save_settings();
    			LOG_INF("Settings successfully saved");
    BT callbacks are running in interrupt context, and you should not call such functions directly from interrupts.
    Håkon
  • Aha, that explains it.
    Thanks very much for your support.
