I am using the nrf5340 audio example project. The main problem is that I can not receive more than 5 bytes on UARTE1 at 921600 if logging is enabled. There is no event if I try to send more than 5 bytes of data. I guess that log module somehow crashes. If I disable the CONFIG_LOG macro from the .conf file everything starts working fine. But at a 115200 baud rate, UARTE1 receiving works fine while receiving big amounts of data, even if logging is enabled.
This is my device tree configuration:
/* * Copyright (c) 2020-2022 Nordic Semiconductor ASA * * SPDX-License-Identifier: Apache-2.0 */ #include "audio_gateway_nrf5340_cpuapp_common-pinctrl.dtsi" / { chosen { zephyr,console = &uart0; zephyr,shell-uart = &uart0; zephyr,uart-mcumgr = &uart0; zephyr,bt-mon-uart = &uart0; zephyr,bt-c2h-uart = &uart0; zephyr,bt-hci-rpmsg-ipc = &ipc0; }; gpio_fwd: nrf-gpio-forwarder { compatible = "nordic,nrf-gpio-forwarder"; status = "okay"; uart { gpios = <&gpio1 9 0>, <&gpio1 8 0>, <&gpio1 11 0>, <&gpio1 10 0>; }; }; }; &adc { status = "okay"; }; &gpiote { status = "okay"; }; &gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &uart0 { status = "okay"; current-speed = <115200>; pinctrl-0 = <&uart0_default>; pinctrl-1 = <&uart0_sleep>; pinctrl-names = "default", "sleep"; }; &uart1 { status = "okay"; compatible = "nordic,nrf-uarte"; current-speed = <921600>; pinctrl-0 = <&uart1_default>; pinctrl-1 = <&uart1_sleep>; pinctrl-names = "default", "sleep"; }; &pwm0 { status = "okay"; }; &timer0 { status = "okay"; }; &timer1 { status = "okay"; }; &timer2 { status = "okay"; }; &flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x00000000 0x00010000>; }; slot0_partition: partition@10000 { label = "image-0"; }; slot0_ns_partition: partition@50000 { label = "image-0-nonsecure"; }; slot1_partition: partition@80000 { label = "image-1"; }; slot1_ns_partition: partition@c0000 { label = "image-1-nonsecure"; }; scratch_partition: partition@f0000 { label = "image-scratch"; reg = <0x000f0000 0xa000>; }; storage_partition: partition@fa000 { label = "storage"; reg = <0x000fa000 0x00006000>; }; }; }; / { reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges; sram0_image: image@20000000 { /* Zephyr image(s) memory */ }; sram0_s: image_s@20000000 { /* Secure image memory */ }; sram0_ns: image_ns@20040000 { /* Non-Secure image memory */ }; }; }; /* Include partition configuration file */ #include "audio_gateway_nrf5340_cpuapp_partition_conf.dts" // #include "audio_gateway_nrf5340_shared.dts"
This is my pins configuration:
/* * Copyright (c) 2022 Nordic Semiconductor ASA * * SPDX-License-Identifier: Apache-2.0 */ &pinctrl { uart0_default: uart0_default { group1 { psels = <NRF_PSEL(UART_TX, 0, 20)>, <NRF_PSEL(UART_RTS, 0, 19)>; }; group2 { psels = <NRF_PSEL(UART_RX, 0, 22)>, <NRF_PSEL(UART_CTS, 0, 21)>; bias-pull-up; }; }; uart0_sleep: uart0_sleep { group1 { psels = <NRF_PSEL(UART_TX, 0, 20)>, <NRF_PSEL(UART_RX, 0, 22)>, <NRF_PSEL(UART_RTS, 0, 19)>, <NRF_PSEL(UART_CTS, 0, 21)>; low-power-enable; }; }; uart1_default: uart1_default { group1 { psels = <NRF_PSEL(UART_TX, 1, 14)>; }; group2 { psels = <NRF_PSEL(UART_RX, 1, 15)>; bias-pull-up; }; }; uart1_sleep: uart1_sleep { group1 { psels = <NRF_PSEL(UART_TX, 1, 14)>, <NRF_PSEL(UART_RX, 1, 15)>; low-power-enable; }; }; };
I thought that the reason could be easyDMA but couldn't find enough information about it. What do you think can be the cause of this trouble?
