Radio Notification
Radio Notification
In this tutorial we will set up a beacon example and modify it to use radio notification. Then we will use radio notification to light a LED when the radio is transmitting.
While this is a relatively simple example, radio notification has some very powerful uses. You can for example use radio notification to finish those last second calculations before the SoftDevice takes control of the processor core.
Tools
Start off by downloading and installing the command line tools executable.
  • nrfjprog --help
In windows 7 navigate to environment variables by (for other systems consult the link above):
  • Pressing: Win+Break
  1. Then click on Advanced system settings
  2. Click on Environment Variables...
Setting up the example
This tutorial assumes you have read and completed the tutorials on Setting up an example project on the nRF51 DK and BLE Advertising, a beginner's tutorial. For this tutorial we will use the ble_app_beacon example for SoftDevice S130/S132. Download and extract the SDK, the project can be found in:
  • nRF 51 DK..\examples\ble_peripheral\ble_app_beacon\pca10028\s130\arm5_no_packs
  • nRF 52 DK..\examples\ble_peripheral\ble_app_beacon\pca10040\s132\arm5_no_packs
The SoftDevice hex file can be found in
  • nRF 51 ...[YOUR_SDK11_LOCATION]\nRF5_SDK_11.0.0_89a8197\components\softdevice\s130\hex
  • nRF 52 ...[YOUR_SDK11_LOCATION]\nRF5_SDK_11.0.0_89a8197\components\softdevice\s132\hex
Program the hex file by first erasing and the programming the chip with:
nRF51
nrfjprog --family nRF51 --eraseall
nrfjprog --family nRF51 --program [SOFTDEVICE_LOCATION]\s130_nrf51_2.0.0_softdevice.hex
nRF52
nrfjprog --family nRF51 --program [SOFTDEVICE_LOCATION]\s132_nrf52_2.0.0_softdevice.hex
Next, compile the code in Keil and flash to your device. Verify that everything is working correctly by checking that LED1 is blinking to indicate advertising, further/alternate verification is possible by checking Master Control Panel for relevant beacons.
The radio notification function
In this tutorial we will describe how to set up radio notifications using the SoftDevice API, the documentation can be found here. If you want to use the SDK 11 functions be aware of this bug.
First we will have to add nrf_nvic.h to our project in order to be able to use sd_nvic functions. Include it by adding
#include nrf_nvic.h
to the includes at the top of main.c.
Next we will create a function and include it in our code, above main. The different parameters will be discussed in the next section.
/**@brief Function for initializing Radio Notification Software Interrupts.
uint32_t radio_notification_init(uint32_t irq_priority, uint8_t notification_type, uint8_t notification_distance)
    uint32_t err_code;
    err_code = sd_nvic_ClearPendingIRQ(SWI1_IRQn);
    if (err_code != NRF_SUCCESS)
        return err_code;
    err_code = sd_nvic_SetPriority(SWI1_IRQn, irq_priority);
        return err_code;
    err_code = sd_nvic_EnableIRQ(SWI1_IRQn);
        return err_code;
    // Configure the event
    return sd_radio_notification_cfg_set(notification_type, notification_distance);
Radio notification uses software interrupt 1 for its returns, for this tutorial we will use the event handler to toggle the status of a LED. Add the following handler above main.
/**@brief Software interrupt 1 IRQ Handler, handles radio notification interrupts.
void SWI1_IRQHandler(bool radio_evt)
    if (radio_evt)
        nrf_gpio_pin_toggle(BSP_LED_2); //Toggle the status of the LED on each radio notification event
Note that a BSP binding is used to ensure code compatibility between nRF51 DK and nRF52 DK.
Configuring radio notifications
To initialize radio notification using our function we will utilize some predefined enumerators and structs.
nRF51: The interrupt priority is a value from 0 to 3, where 0 corresponds to highest priority. 0 and 2 are reserved values, i.e. we have a choice between:
  • Application High priority - 1
  • Application Low priority - 3
nRF52: The interrupt priority is a value from 0 to 7, where 0 corresponds to the highest priority. 0, 1, 4 and 5 are reserved values and we have a choice between priority levels 2, 3, 6 and 7.
The distance is the time window before/after the radio goes active. The radio events are radio_on and radio_off, e.g. a notification distance of 800µs corresponds to a radio notification event 800µs before the radio goes active, and another event right after the radio has gone inactive. The different distances are shown below.
/**@brief Possible values of notification_distances */
enum NRF_RADIO_NOTIFICATION_DISTANCES
  NRF_RADIO_NOTIFICATION_DISTANCE_NONE = 0, /** The event does not have a notification. */
  NRF_RADIO_NOTIFICATION_DISTANCE_800US,    /** The distance from the active notification to start of radio activity. */
  NRF_RADIO_NOTIFICATION_DISTANCE_1740US,   /** The distance from the active notification to start of radio activity. */
  NRF_RADIO_NOTIFICATION_DISTANCE_2680US,   /** The distance from the active notification to start of radio activity. */
  NRF_RADIO_NOTIFICATION_DISTANCE_3620US,   /** The distance from the active notification to start of radio activity. */
  NRF_RADIO_NOTIFICATION_DISTANCE_4560US,   /** The distance from the active notification to start of radio activity. */
  NRF_RADIO_NOTIFICATION_DISTANCE_5500US    /** The distance from the active notification to start of radio activity. */
The TYPE enumeration allows you select between
  • NRF_RADIO_NOTIFICATION_TYPE_NONE - Triggers no interrupts
  • NRF_RADIO_NOTIFICATION_TYPE_INT_ON_ACTIVE - Triggers interrupt before a radio event
  • NRF_RADIO_NOTIFICATION_TYPE_INT_ON_INAVTIVE - Triggers interrupt after a radio event
  • NRF_RADIO_NOTIFICATION_TYPE_INT_ON_BOTH - Triggers interrupt before and after radio event
In the SoftDevice Specification different examples of signals can be seen.
Running the example
Radio notifications should always be initialized/deinitialized when the SoftDevice is guaranteed to be inactive, for example right after it is initialized. Lets set up a radio signal with low priority that is active 800 µs before the radio event occurs. In main, after ble_stack_init(); we add
err_code = radio_notification_init(3, NRF_RADIO_NOTIFICATION_TYPE_INT_ON_ACTIVE, NRF_RADIO_NOTIFICATION_DISTANCE_800US);
APP_ERROR_CHECK(err_code=);
Compile and flash the project. The blinking frequency of the LED will change proportionally to the advertising interval.
Final notes and further reading
Radio notification is a powerful tool that can be essential in making your application. Some useful information can be found below.
