##Prerequisites
- Python 2.7
###Tested using
- Ubuntu 14.04.3
- Wireshark version 1.12.0
###Dependencies
For Ubuntu:
###Build
Compile wireshark:
$ ./wireshark
##Flash firmware
##Linux example code
pip install pyserial
ls -l /dev/ttyACM0
Run the example script:
sudo python linux_example.py
matrach
matrach
