BLE Sniffer in Linux using Wireshark
##Prerequisites
  • nRF Dongle (PCA10031/PCA10000) or similar
  • Working installation of SEGGER J-Link drivers (To flash the chip with the firmware)
  • Python 2.7
###Tested using
  • Ubuntu 14.04.3
  • Wireshark version 1.12.0
###Dependencies
For Ubuntu:
###Build
  • Download the Wireshark plugin: nordic_ble_linux-1.12.0.zip
  • Download the Wireshark source: wireshark-1.12.0.tar.bz2
  • Decompress wireshark-1.12.0.tar.bz2 and move into created folder (wireshark-1.12.0)
  • Decompress nordic_ble_linux-1.12.0.zip in plugins folder
  • Move Custom files to plugins folder
  • Add packet-nordic_ble.c from the "wireshark_dissector_source" folder in the Sniffer API to plugins/nordic_ble folder
  • Compile wireshark:
  • Then run wireshark to see if it works:
    $ ./wireshark
##Flash firmware
##Linux example code
  • Download the example python script here: example_linux.py
  • Put it in the Sniffer API root folder (Called "SnifferAPIBuild" after the unzip)
  • install the "pyserial" python 2.7 package:
    pip install pyserial
ls -l /dev/ttyACM0
Run the example script:
sudo python linux_example.py
  • Getting fallowing error with wireshark1.12.0 source. I tried the above mentioned steps
    Making all in nordic_ble make[3]: Entering directory /home/kiran/wireshark-1.12.0/plugins/nordic_ble' make[3]: *** No rule to make targetall'. Stop. make[3]: Leaving directory /home/kiran/wireshark-1.12.0/plugins/nordic_ble' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory/home/kiran/wireshark-1.12.0/plugins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/kiran/wireshark-1.12.0' make: *** [all] Error 2
