Control data from the phone needed to be sent frequently enough to keep the quadcopter under control. Obviously, this data stream can only tolerate a very small amount of latency before the quadcopter careens out of control and heads straight for a defenseless houseplant (in this case, failure smells a lot like a freshly-trimmed lawn).
The quadcopter needed to receive a sufficient number of control packets to not only keep it under control but also prevent it from thinking that its transmitter had gone away.
###2) Housekeeping ExistsTimeslots May Be Difficult To Predict
In the following screenshot a pin is being set high at the beginning of each timeslot and set low at the end. The space between consecutive timeslots is being used by the SoftDevice for BLE connection events. Normally, the radio is split evenly. However, every 13th timeslot is delayed. due to the SoftDevice requiring more time during the preceding connection event
The reason that One of the possible reasons for why this happens is because the SoftDevice periodically spends some time to do chores and clean up its scheduling mechanism. This process is done in the link layer module, is done at the end of selected radio events, and runs in the radio's elevated interrupt priority.
In the context of this post, I refer to this activity as "housekeeping." However, this term is not part of the official SoftDevice nomenclature.
Stanislav Silnitskiy
