Preparation
- Raspberry Pi with Installed raspbian and 6LowPAN module
Following IoT SDK pages
Go to HE website
Create your account
※ Needs verification your account on your written email address after created account
Login and Create Regular Tunnel
- Insert your own IPv4 address and select closest server by your location (In this case “Tokyo,JP”)
▣ It will check automatically after you entered your IPv4 address
※ if you have issue as below you need to configure router to allow pinging from external server
For My case I enabled WAN ping response feature on my router
5. You can get details of tunnel broker information after successfully create tunneling service
- To easily set up tunneling service on your device it provides example configuration.
- Click "Example configurations" tab on "Tunnel Details" web page and select "Debian/Ubuntu" for linux OS
- Copy and add this information to RPi. interface file
auto he-ipv6
iface he-ipv6 inet6 v4tunnel
address 2001:470:23:8a7::2
netmask 64
endpoint 74.82.46.6
local 211.211.74.127
ttl 255
gateway 2001:470:23:8a7::1
auto he-ipv6
netmask 64
endpoint 74.82.46.6
local 192.168.0.190
ttl 255
- Assign IPv6 address to RPi. ethernet port. (in my case used 48bit prefix)
- Configure RADVD configration file.
$ sudo vi /etc/radvd.conf
interface eth0
AdvSendAdvert on;
AdvHomeAgentFlag off;
MinRtrAdvInterval 30;
MaxRtrAdvInterval 100;
AdvDefaultLifetime 9000;
AdvOnLink off;
AdvAutonomous on;
AdvRouterAddr on;
AdvValidLifetime infinity;
DeprecatePrefix on;
- reboot RPi.
$ sudo reboot
- Now you have own your IPv6 address and network!!
Sample configuration files
Tips!! IPv6 Verification
Eugene Yu
Eugene Yu
