Create Hurricane Tunnel Broker on Raspberry Pi
Preparation
  • Raspberry Pi with Installed raspbian and 6LowPAN module
    Following IoT SDK pages
  1. Go to HE website
  2. Create your account
    ※ Needs verification your account on your written email address after created account image description
  3. Login and Create Regular Tunnel
  1. Insert your own IPv4 address and select closest server by your location (In this case “Tokyo,JP”)
▣ It will check automatically after you entered your IPv4 address image description
※ if you have issue as below you need to configure router to allow pinging from external server image description
For My case I enabled WAN ping response feature on my router image description 5. You can get details of tunnel broker information after successfully create tunneling service image description
  1. To easily set up tunneling service on your device it provides example configuration.
    • Click "Example configurations" tab on "Tunnel Details" web page and select "Debian/Ubuntu" for linux OS image description
    • Copy and add this information to RPi. interface file
auto he-ipv6
iface he-ipv6 inet6 v4tunnel
    address 2001:470:23:8a7::2
    netmask 64
    endpoint 74.82.46.6
    local 211.211.74.127
    ttl 255
    gateway 2001:470:23:8a7::1
auto he-ipv6
    netmask 64
    endpoint 74.82.46.6
    local 192.168.0.190
    ttl 255
  1. Assign IPv6 address to RPi. ethernet port. (in my case used 48bit prefix)
  1. Configure RADVD configration file.
$ sudo vi /etc/radvd.conf
interface eth0
    AdvSendAdvert on;
    AdvHomeAgentFlag off;
    MinRtrAdvInterval 30;
    MaxRtrAdvInterval 100;
    AdvDefaultLifetime 9000;
        AdvOnLink off;
        AdvAutonomous on;
        AdvRouterAddr on;
        AdvValidLifetime infinity;
        DeprecatePrefix on;
  1. reboot RPi.
$ sudo reboot
  1. Now you have own your IPv6 address and network!!
Sample configuration files
  1. radvd.conf
  2. sysctl.conf
  3. interfaces
  4. run.sh
Tips!! IPv6 Verification
  1. IPv6-Test
  2. Test-IPv6
  • Sorry for late answer.
    It was trouble in our web service due to this reason I couldn't access this page. I updated as follow suggestion of Mahesh Venkitachalam.
    @ Liverpool007
    In my case I used jessie-lite and It has no issue to use static IP address both IPv4 and IPv6 I will soon to upload my all configuration files.
    Thank you!
    @ Liverpool007
    Thank you!
