- nrfjprog --help
Pressing: Win+Break or
Opening Control Panel >> System >> Advanced >> Environment Variables or
Right-clicking My Computer and click on properties
Then click on Advanced system setting
Click on Environment Variables...
Then press OK. Now you will be able to see the help dialog when you type nrfjprog --help
in a new command line.
- Pressing Tools >> Customize Tools Menu...
If you are using nRF52 you will have to specify --family nrf52
as an additional argument, like this:
Programming SoftDevices
The parameters are:
- Command: nrfjprog
- Initial Folder:
[YOUR_SDK_LOCATION]\SDK11\components\softdevice\s130\hex
- Arguments: --program s130_nrf51_2.0.0-7.alpha_softdevice.hex
I chose to call my tool program_sd130
, however you can call this anything you like.
Final words
