- nrfjprog --help
Pressing: Win+Break or
Opening Control Panel >> System >> Advanced >> Environment Variables or
Right-clicking My Computer and click on properties
Then click on Advanced system setting
Click on Environment Variables...
- Pressing Tools >> Customize Tools Menu...
If you are using nRF52 you will have to specify --family nrf52 as an additional argument, like this:
Programming SoftDevices
The parameters are:
- Command: nrfjprog
- Initial Folder:
[YOUR_SDK_LOCATION]\SDK11\components\softdevice\s130\hex - Arguments: --program s130_nrf51_2.0.0-7.alpha_softdevice.hex
I chose to call my tool program_sd130, however you can call this anything you like.
Final words
Bastien Reynard
Bastien Reynard
