4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
- Maximum voltage: 4.2 V * (2 M/(0.8 M+2 M)) = 3 V
- Minimum voltage: 2.7 V * (2 M/(0.8 M+2 M)) = 1.93 V
- ADC value at 4.2 V – 12 bit setup: 3 V * (1/5) / 0.6 V * 4095 = 4095
- ADC value at 2.7 V - 12 bit setup: 1.93 V * (1/5) / 0.6 V * 4095 = 2634
- Usable ADC resolution - 12 bit setup: 4095 - 2634 = 1461
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
