4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • Minor nit: "we choose R1 to be 800 KΩ. This is the maximum source resistance we can have if we use an acquisition time of 40 us, see here."
    The series resistance of a resistive voltage divider is the parallel of the two resistors; R1 alone does not determine the series resistance. In this case, series resistance is 1 / ( 1 / 2000 + 1 / 800 ) -> 571.4k. In theory, you could use a larger values for R1 and R2.
