4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • @Luis
    • Yes, the ADCs of nRF51 and nRF52 are of different type. The nRF51 has a single-ended continuous time incremental sigma-delta ADC. The nRF52 has a differential-input successive approximation ADC.
    • The sampling frequency is limited by the sum of sampling time and acquisition time. The maximum sampling time is 2us. For acquisition time of 3us the total conversion time is therefore 5us, which makes maximum sampling frequency of 1/5us = 200kHz. Similarly, if you choose acquisition time of 40us, then the conversion time is 42us and the maximum sampling frequency is 1/42us = 23,8kHz
    • The internal reference is fixed, the VDD reference is relative to the supply voltage. If you want to measure for example battery voltage, you would choose fixed internal reference. If you want however to measure voltage of something that fluctuates relative to the supply voltage (e.g. when battery voltage drops), you can choose VDD/4 as reference to make the measurement independent of the fluctuations in the supply voltage.
    • ENOB
    • We do not recommend connecting a GPIO to limit the current through the voltage dividier. It could expose the ADC input pin with higher voltage than supply voltage when no current flows through the voltage divider.
  • @Luis
    • ENOB
