4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • ...coninue question
    I have 2 questions about this feature
    1. Is it working now?
       I read errata notification (#160) that "VDDHDIV5 is not functional".
    2. Why to divide by 5?
       We can't use internal reference with this divisor because of 4.2V / 5 = 840mV
       840 mV exceeds internal reference 600 mv, that means over-saturation.
       If we will use USB power supply (VBUS max = 5.5V), it become even worse (1100 mV)
