4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • Great info just in time. Some points I think you should point out:
    • A big difference with nRF51 is that no extra capacitor is needed, due to different ADC kind?
    • What is the maximum sampling frequency with different setups? Adquisition time + conversion time?
    • What is the difference or recommendation using internal reference vs vdd reference?
    • Does it make any sense using 12 bits resolution if datasheet says that the effective number of bits is only 9, or did I understand this the wrong way?
    • In what cases should oversampling be used and how does it affect?
    • Is it feasible to use another gpio as GND in order to be able to use that gpio instead of an external switch when we want minimum current possible?
