4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • It can be a good idea to add a capacitor and we will add more information to the blog later about that and what values that have to be used to ensure the accuracy is within spec. Basically you have to ensure that the sampling frequency is low enough so that the capacitor will charge up sufficiently and that the capacitor value is large enough to keep the voltage while the ADC is sampling.
    For example see the "determine capactitor size" part in the Measuring Lithium battery voltage with nRF51 blog post, more specifically the calculations for capacitor size on nRF51 can be found here. These are the calculations for nRF51, the same equations are not true for nRF52, since the ADC is different on nRF52. We will add the calculations later when we have done some tests here.
