4.2 V / 2.8 MΩ = 1.5 uA
Usable ADC resolution
Using capacitor
Choosing the capacitor value
Vsaadc / Vain = 1 – 1 / 2^12
Cext = Csample * 2^12
Cext = 2.5 pF * 2^12 ~= 10nF
Example
  • Hi Ole Bauck,
    As mentioned in datasheet input impedance of the ADC pin is >1M ohm.
    It means if we use a voltage divider circuit then the impedance of voltage divider should not exceed the input impedance of the ADC pin. please correct me if I'm wrong.
    Does higher value of external impedance at ADC pin affect the performance?
    If I'm selecting this value  R1 = 4MOhm, R2 = 10MOhm, Cext = 10nF, it is fine for >1M ohm impedance?
     Thank you
    Shashikant
  • Hi Ole Bauck,
     Thank you
    Shashikant
