Table of Contents
Change log
- 31/08/2021 10:00 AM - Ali Aljaani - Initial blog.
- 22/09/2021 11:00 AM - Ali Aljaani - Changed download procedure from external VSIX file to integrated in Visual Studio Marketplace.
nRF Connect for VS Code Interface
VS Code is a fast, cross-platform, and popular IDE. Nordic Semiconductor’s nRF Connect extension turns VS Code into a complete IDE for developing applications for nRF91, nRF53 and nRF52 Series devices on Windows, macOS or Linux. This includes an interface to the compiler and linker, an RTOS-aware debugger, a seamless interface to the nRF Connect SDK, and a serial terminal.
- nRF Connect for VS Code, the main extension, which contains an interface to the build system and nRF Connect SDK, as well as external tools such as guiconfig.
- DeviceTree for the Zephyr Project, which provides DeviceTree language support.
- Kconfig for the Zephyr Project, which provides Kconfig language support.
- nRF Terminal, a serial and RTT terminal.
As explained in the first video, to install the bundle(extension pack), open the Extensions menu from the VS Code toolbar and type Nordic, select nRF Connect Extension Pack and click on Install as shown in the illustration below:
The nRF Connect for VS Code extension is undergoing continuous updates. Written documentation is available in the readme file published as part of the extension bundle. You can find it by clicking nRF Connect (as shown in the screen shot below) in the Extensions menu in the VS Code toolbar. During testing, please check the Known Issues chapter if you encounter issues.
Stay tuned as more features and video tutorials are under development and will be available to you soon. If you have any issues related to this bundle, please submit a DevZone ticket.
ENJOY!
