nRF Connect for VS Code
Change log
VS Code is a fast, cross-platform, and popular IDE. Nordic Semiconductor’s nRF Connect extension turns VS Code into a complete IDE for developing applications for nRF91, nRF53 and nRF52 Series devices on Windows, macOS or Linux. This includes an interface to the compiler and linker, an RTOS-aware debugger, a seamless interface to the nRF Connect SDK, and a serial terminal.
Tutorial Videos
Setup basic configuration
Stay tuned as more features and video tutorials are under development and will be available to you soon. If you have any issues related to this bundle, please submit a DevZone ticket.
ENJOY!
  • Currently, under macOS 10.16,  I can create a new project and build it without any issues. However, none of my nRF52840 boards appear under the CONNECTED DEVICES tab and therefore cannot flash the programs.
    When I run the nRF Terminal, nRF Connect/VSC sees the nrf52840 board and I can connect to it. The VSC status bar acknowledges the connect but nothing appears under the CONNECTED DEVICES tab.
    It looks like the nRF Connect extension under macOS isn’t quite working yet. It would be great to get a fix, as the nRF Connect for VSC looks excellent and very promising for the future. Thank you.
