nRF Connect for VS Code
Change log
VS Code is a fast, cross-platform, and popular IDE. Nordic Semiconductor’s nRF Connect extension turns VS Code into a complete IDE for developing applications for nRF91, nRF53 and nRF52 Series devices on Windows, macOS or Linux. This includes an interface to the compiler and linker, an RTOS-aware debugger, a seamless interface to the nRF Connect SDK, and a serial terminal.
Tutorial Videos
Setup basic configuration
Stay tuned as more features and video tutorials are under development and will be available to you soon. If you have any issues related to this bundle, please submit a DevZone ticket.
ENJOY!
