nRF Connect for VS Code
Change log
VS Code is a fast, cross-platform, and popular IDE. Nordic Semiconductor’s nRF Connect extension turns VS Code into a complete IDE for developing applications for nRF91, nRF53 and nRF52 Series devices on Windows, macOS or Linux. This includes an interface to the compiler and linker, an RTOS-aware debugger, a seamless interface to the nRF Connect SDK, and a serial terminal.
Tutorial Videos
Setup basic configuration
Stay tuned as more features and video tutorials are under development and will be available to you soon. If you have any issues related to this bundle, please submit a DevZone ticket.
ENJOY!
  • Excellent quick response from Nordic Semi Support Engineering. Thank you Vidar for the workaround, for my nRF Connect for VS Code issue on macOS.
    Hopefully, the next nRF Connect extension release will have a proper fix.
    On macOS (11.6, 10.13.6, and 10.14.6), the nRF Connect extension attempted to select PyOCD when it sees that a J-link (e.g. Segger J-Link Edu Mini) is already connected. The workaround was to modify the board.cmake (in my case, particle_xenon) in the Zephyr directory in order for the nRF Connect to flash. The include with nrfjprog had to be made the default runner by moving it to the top of the includes.
    Now, I’m able to build and flash programs to my nRF52840 particle_xenon boards without any issues. Awesome!
    The nRF Connect for VS Code environment is turning out to be superb. I’m certain that as new features get added and the extensions made more robust, we’ll have an excellent dev environment. So many things to checkout with nRF Connect, including testing out debug functionality.
    Once more, kudos to Nordic Semi for the excellent nRF Connect for VS Code and their highly professional Support Engineering.
