*New nRF Connect logo*
About nRF Connect
*nRF Connect screenshot*
RC feedback request
Release change log
nRF52 support
Improved UART transport
New GAP features
- Security
- Bonding (key storage)
- Max 1 peripheral connection
New GATT features
UI change
Known issues/limitations
OSX Segger issue
Roadmap
Release v1.0
Source code on GitHub
File downloads
Connectivity firmware
Firmware for OSX issue
Nic
Nic
