This page describes an easy workaround for the flashing error you get in Keil uVision when you are using nRF5 SDK v16 on nRF52833 chips.
The assumption is that you have installed the latest versions of nRF MDK and nRF-Command-Line-Tools before applying this workaround.
Option 1)
Option 2) You can also do a small configuration change in the flash tool to use nrfjprog command-line tool to be used instead of the native Keil flashing tool.
Update
Happy coding.
Good Work, i like the way you describe this topic, keep going. i would like to share some useful security links here please go through
mcafee.com/activate
www.mcafee.com/activate
mcafee activate
Thank you for sharing this blog , It is an amazing blog , I am really impressed by your blog
Norton Antivirus Security Online
norton.com/setup
www.norton.com/setup
norton.com/setup activate
norton product key
This is a great post and very useful. Lots of great information thank you for sharing, are you interest to Sahih Sitta Hadith
I am using nRF52832
What will be the start address for 8.31.0 ? Will it be same as you mentioned above? I changed the address to the one you mentioned above but I am still not able to download the hex, its showing error "Error flash download fail"
